Femme_physics said:
You seem to have a short circuit across the capacitor and so across the rest of your circuit apart from the top resistor ( presumably R1)
Kirchoff's Laws really only apply to a stable situation, so a charging capacitor would be analysed by taking a "snapshot" of the circuit operation.
The two parallel resistor-diode circuits can be analysed by getting the parallel resistor combination and putting it in series with one diode.
You can do this because both diodes will drop 0.7 volts, so you can join their anodes together and no current will flow between points of equal voltage.
For example, let R1 = 1000 ohms, R2 = 2000 ohms, R3 = 3000 ohms Diode voltage = 0.7 volts.
Parallel R2 and R3 = 1200 ohms call this R4
So voltage across R1 and R4 = 15 - diode voltage = 14.3 volts.
Current in R1 and R4 = 14.3 Volts / (1000 ohms + 1200 ohms) = 0.0065 amps
Voltage across R4 if C wasn't there = IR = 0.0065 * 1200 = 7.8 volts
R4 plus diode voltage = 8.5 volts
So this is the maximum voltage that C could charge to, if it didn't have a short circuit on it. :)
