Amout of energy needed to warm air
  • Thread starter Thread starter troymcfont
    Air Energy
To calculate the energy required to heat air from 20 °C to 100 °C in a volume of 1680 cm³, the specific heat of dry air (1.0 kJ/kg-K) and the density of dry air (0.0013 g/cm³) are used. The total mass of the air in this volume is approximately 2.2 grams or 0.0022 kg. The energy needed for an 80 °C increase is calculated using the formula E = specific heat * mass * temperature change. This results in an energy requirement of 0.18 kJ or 180 J. The discussion highlights the importance of using correct constants for accurate calculations.
troymcfont
Hi,
How do I calculate the amount of energy needed to warm air from 20 °C to 100 °C in a constant volume (1680 cm3)?
Thank you.
The specific heat of dry air is about 1.0 kJ/kg-K, and the density of dry air is .0013 g/cm^3, so the air in 1680 cm^3 will weigh 2.2 g or 2.2E-3 kg. So to heat it up 80 C will take:
E = 1.0 kJ/kg-K * 2.2E-3 kg * 80 K = 0.18 kJ = 180J.
Here's a good source for some of these constants.
Thank you!
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
