Design Amplifier w/ 1k & 10k Resistors for +10 V/V Gain
  • Thread starter Thread starter STEMucator
    Amplifier Design
The discussion focuses on designing a non-inverting amplifier circuit with a gain of +10 V/V using only 1 kΩ and 10 kΩ resistors. The gain formula for a non-inverting amplifier is established as ##\frac{v_o}{v_i} = 1 + \frac{R_2}{R_1}##, leading to the requirement that ##\frac{R_2}{R_1} = 9##. To achieve this gain, the solution involves using a combination of resistors, including adding resistors in parallel and series to create the necessary resistance values. The final configuration suggests using 10 kΩ for ##R_1## and a combination of 1 kΩ resistors to achieve the required ##R_3## value.
  • Understanding of non-inverting amplifier configurations
  • Familiarity with resistor combinations in series and parallel
  • Knowledge of gain calculations in operational amplifiers
  • Basic circuit design principles
  • Explore advanced operational amplifier design techniques
  • Learn about feedback resistor configurations in amplifiers
  • Research the impact of input and output impedance on amplifier performance
  • Study resistor networks and their applications in circuit design
Electrical engineers, circuit designers, and students studying analog electronics who are interested in amplifier design and optimization techniques.
STEMucator
Given the availability of resistors of value 1 kΩ and 10 kΩ only, design a circuit based on the non-inverting configuration to realize a gain of +10 V/V.
So I was doing some of those good old design problems, and I came across this one.
I know the gain of the standard non-inverting configuration is given by ##\frac{v_o}{v_i} = 1 + \frac{R_2}{R_1}##. So I want to design the circuit such that:
$$10 = 1 + \frac{R_2}{R_1} \Rightarrow \frac{R_2}{R_1} = 9$$
I'm limited to only the ##1k## and ##10k## resistors provided, and this provides a design problem. Usually, we would like the input impedance to be a large as possible to retain as much of the signal in accordance with ##V = IR##. Similarly, we would like the output impedance to be as small as possible. Looking at the equation:
$$\frac{R_2}{R_1} = 9$$
It doesn't take long to realize I must choose ##R_1 << R_2##, which of course is the exact opposite of what a good amplifier should have. Ideally I want to choose ##R_1 >> R_2##, but I can't figure out the ideal resistor values.
Is this just a bad amplifier design?
If Vin is applied to the + input of the op amp then the input impedance it sees is that of the op amp, i.e. very large indeed. The feedback loop involves the op amp output and the - input of the op amp only.
Don't be afraid to stick several of the available resistors in series to make up larger values, after all it is an academic not an economic exercise :)
The inverting amplifier suffers from a low input impedance problem in general; it causes a problem because ##R_2## can potentially be unrealistically large (this is easy to see considering the inverting amplifier gain). The problem can be corrected by adding a few extra resistors around ##R_2##; Adding a resistor ##R_3## in parallel with ##R_2## using the virtual ground at the input terminals, and a resistor ##R_4## just before the output node.
The gain is then (which we want to be 10V/V):
$$\frac{v_o}{v_i} = - \frac{R_2}{R_1}\left(1 + \frac{R_4}{R_2} + \frac{R_4}{R_3} \right) = 10 \frac{V}{V}$$
Choosing ##R_1 = 10k##, we would need to choose ##R_2 = 10k## so the first term is unity. This makes it easier to select ##R_4## and ##R_3## so the gain is 10. Choosing ##R_4 = 10k## to preserve the signal, and ##R_3 = 0.833k## to satisfy the equation, the circuit will realize a gain of 10.
Now there's an issue, I can only use ##1k## and ##10k## resistors, so ##R_3## is going to have to be some combination of resistors.
Sticking 5 ##1k## resistors in series, and then putting those in parallel with another ##1k## resistor, provides the desired resistance.
How about one feedback resistor & one to gnd, then dividing the + input down to get Av = 10?
Total no. of resistors = 4.
  • · Replies 16 ·
