Amplitude will change after unpolarised wave passes through a polariod
The amplitude of an unpolarized wave will decrease when it passes through a polarizer. The extent of this reduction depends on the initial polarization state of the light. If the light is unpolarized, it will lose some amplitude upon passing through the polarizer. For precise outcomes, the polarization of the light source must be known. Understanding these principles is crucial for analyzing light behavior in various applications.
tipsyteong
Can i know whether the amplitude will change after unpolarised wave passes through a polariod?
Science news on Phys.org
I don't think so..try reading here...I skimmed but did not see a clear cut answer.
http://en.wikipedia.org/wiki/Polarized_light
Under polarization effects in everyday life I found :
If two polarizers are placed atop one another at 90° angles to one another, there is minimal light transmission.
which sounds like amplitude reduction ?
You can't know that unless you know the polarization of the light before it reaches the polaroid filter, so you either need to know the polarization of your light source, or pass it through a known polarizing filter beforehand.
If you know for a fact that the light is unpolarized, its amplitude will definitely decrease as it passes through a polarizer.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
