An ideal simple gas turbine has a compression ratio of 5. What is its
An ideal simple gas turbine with a compression ratio of 5 is discussed, focusing on calculating its efficiency and work ratio. The turbine produces 6 MW while the compressor requires 2 MW, leading to an efficiency calculation using the specific heat ratio of air, which is 1.4. The discussion highlights the need for additional information to determine heat rejection accurately, emphasizing the relationship between turbine efficiency and heat input. The conversation reveals that the original problem statement was incomplete, prompting requests for clarification. Ultimately, the participants aim to solve for efficiency and heat rejection based on the given parameters.
qablos
c=r(γ-1/γ)
η=1-(1/c)
I'm stuck, I think I need to use the above equations and possibly more. I just don't know how to find a value for the ratio of specific heats,γ.
Do you have any other information about the compressor apart from its pressure ratio?
Yeah:
"The turbine
produces 6 MW (gross) and the compressor requires 2 MW to drive it."
It's just put after the question, so I assumed I need to use the compression ratio which is 5.
Given the pressure ratio alone, I don't think you can find the ratio of the specific heat capacities.
I am assuming that is what you were asked to find.
Can you post the entire text of the problem? It looks like something is missing after
"What is its ..."
"What is its ..."
An ideal simple gas turbine has a compression ratio of 5. What is its efficiency? If the turbine
produces 6 MW (gross) and the compressor requires 2 MW to drive it, what is the work ratio and how much heat is
rejected?
The ratio of specific heats is that for air, which is 1.4
I've done it now thanks!
But how do I calculate the heat rejected? :/
I assume that the efficiency for the turbine was not 1.0. You know how much work output was obtained from the turbine. The efficiency of the turbine relates the output to the total heat input.
