quasar987 said:
I don't know if this counts as an analogy to you but for one, both vectors and covectors are vectors. And given a basis {v_1,...,v_n} of vectors, there is a natural basis {f_1,...,f_n} of covectors given by f_i(v_j)=1 if i=j and =0 otherwise.
Yes, it's because of this interplay of vectors and covectors - ie. a vector is a covector to a covector, and a covector is a vector when the original vector is considered a covector - that I wanted to know if it extended beyond vector spaces.
If you consider a trajectory, then you can define a velocity at every point along the trajectory. However, a velocity is actually meaningless on its own, and you have to specify a reference, such as a velocity with respect to some scalar field(s). So in some sense, it is better to consider the velocity vector as an operator, which is what a vector is with respect to a covector anyway. The scalar field defines a reference frame, which defines a covector at each point of the trajectory. The covector defined by the reference scalar field acting on the velocity vector gives the speed.
So anyway - trajectories or curves define vectors, and scalar fields define covectors.
mathwonk said:
what is a congruence of curves? and how does it define a vector field? i.e. before finding a statement analogous to yours i need to understand your statement.
Instead of just having a vector at a point, we can have vectors at every point in space. Since a trajectory gives rise to vectors, we can think of a vector field as being formed by many trajectories, all laid side by side so that they cover the entire space. That is what I mean by a congruence of curves, and why a congruence of curves gives rise to a vector field.
From the point of view of vector spaces, covectors and vectors are completely analogous. However, going to trajectories and scalar fields there is no analogy, because a trajectory is a map from the real numbers into the space, and a function is a map from the space into the real numbers (though I guess coordinates are sometimes specified as maps from the real numbers into the space, but you need N of them). I just wanted to know which wins out - the vector space analogy, or the lack of analogy between functions into and functions from the real numbers.
