Analyze this circuit with 2 sources and 4 resistors
The discussion revolves around analyzing a circuit with two sources and four resistors, focusing on current flow, the meaning of a dependent source, and the configuration of resistors. Participants are exploring the application of nodal analysis and Kirchhoff's laws to understand the circuit's behavior.
  • Homework-related
  • One participant questions how current flows in the circuit and the actual path it takes, regardless of the diagram's directions.
  • Another participant explains that the "5i" above the dependent source represents a voltage dependent on the current through a specific resistor.
  • There is a request for clarification on whether two resistors are in series or parallel.
  • Some participants emphasize the need for the original poster (OP) to show their work and attempt to set up Kirchhoff's Current Law (KCL) equations.
  • Multiple participants discuss the independence of equations needed for a unique solution, with some suggesting that the proposed equations may not be independent.
  • There are differing opinions on the role of the 6-ohm resistor, with some stating it has no effect on the circuit's analysis.
  • Participants express the need for clearer definitions of currents at each node and the implications of dependent sources on the analysis.
  • Several participants engage in clarifying the relationship between voltages and currents in the context of the circuit analysis.
Participants do not reach a consensus on several points, including the independence of equations, the role of the 6-ohm resistor, and the correct interpretation of the dependent source. The discussion remains unresolved with multiple competing views.
Participants highlight the importance of defining nodes and currents clearly, as well as the need for independent equations in circuit analysis. There are references to potential communication issues regarding the definitions and roles of various components in the circuit.
mkamalzayed
New user has been reminded to show more effort on their schoolwork threads at PF
Find v1,v2,v3 using nodal analysis
"I in" ="I out" (KCL)
How does the current flow in this circuit and what is its actual true path, regardless of any directions in the figure?
What does the “5i” above the dependent source mean, and does the current flow according to the dependent source or the independent source?
Are the two resistors 2 ohms and 6 ohms connected in series or parallel?
I want to know more and more from the Veterans in electricity
Hi, :welcome:
That is asking for the final answer. You'll have to carry out the analysis to find it :wink:. I.e. set up a system of N equations with N unknowns and solve.
The diamond
represents a dependent voltage source of ##5i## Volts, where ##i## is the current through the ##2\Omega## resistor (
in the diagram). Be sure to use the correct sign.
Thread closed for Moderation...
Thread is reopened provisionally.
@mkamalzayed -- You are required to show more effort before we can offer tutorial help. Please show us your attempt at setting up the KCL equations, and begin to solve them. I will send you a Personal Message (PM) with some tips for how to use LaTeX to post math equations at PF.
User is reminded *again* to show their work on the problem so that we can help them
BvU said:
Hi, :welcome:
The diamond View attachment 353099 represents a dependent voltage source of ##5i## Volts, where ##i## is the current through the ##2\Omega## resistor (View attachment 353100 in the diagram). Be sure to use the correct sign.
Explain more and more
Sigh. Thread is closed again for a bit...
I'm in a PM conversation with the OP at the moment; I'll try to get them to show some effort so we can reopen the thread.
Okay, whew. OP has shown me their work on the problem, so I'll reopen the thread (still provisionally) so they can upload it. I am working with them to help them learn LaTeX, but for the moment they will upload a picture of their hand-written work. (the quality is not too bad, just a little dark)
I don't the final answer
I want to understand the figure and how the current flows and from any source ???? and I want to understand everything about this figure
mkamalzayed said:
Homework Statement: Find v1,v2,v3 using nodal analysis
Relevant Equations: "I in" ="I out" (KCL)
I want to know more and more from the Veterans in electricity View attachment 353084
Please upload the picture of your work so others can see what you have done. Thanks.
Go ahead
Can you check your statements
Perhaps it is useful to explicitly declare the three (!) currents at each node.
And 'node 2 has a dependent voltage source' makes no sense!
It's all pretty basic: you have defined three nodes. At each node KCL says ##\sum i=0##.
If you followed my advice
you have something like the following diagram in front of you:
[edit] the current entering node 3 is named i5, not i4. Updated the image.
No worries about the directions of the currents: the correct sign will come out in the analysis.
The KCL for the three nodes give you three equations, Ohm's law four and the two sources two. Nine equations in nine unknowns. Straightforward math to find e.g. ##v_2## first, then ##v_1## and ##v_3##.
If you still need 'more and more', you'll first have to clearly summarize what you know already and what it is that inhibits you from dealing with this exercise.
In order to get a unique solution, the equations must be independent. The nine you propose are not independent.
Besides which the TS seems to be gone away.
  • Skeptical
Maybe you meant sufficient instead of independent?
Which implies some KVL equations. Let's say a solution is defined by finding the 6 currents, then you only need 6 independent equations. These could be 3 KCL nodes and 3 KVL loops, with Ohm's law to connect them. I bet I could solve this with @BvU 's prescription. Except for the problem of being too busy, too lazy, and not really excited by the solution, whatever it is.
The two equations for the sources are ##v_1=v_2+25## V and ##v_3=v_2+5i## V.
In other words, i5 is not indpendent of i. Likewise, v2 is not independent of v1. These are constraint equations.
Since a network with 3 nodes like this would need at most 3 equations to solve it, given more than 3 equations they are not all independent.
This network needs only one KCL equation and two constraint equations. The 3 nodes can be treated as one supernode.
Note that the 6 ohm resistor does nothing. It can have any value, or it can be missing.
Also note that the problem statement requires a nodal solution.
Checking...
[edit]Aren't we having fun ? Disagreements appear to come from communication issues. Where I think in terms of degrees of freedom and consider something like ##\ v_1-v_2=25\ ## an equation, someone else calls it a constraint.
I agree the answers to 'Find v1,v2,v3 using nodal analysis' is independent of the value of the resistance in the top branch. But I would select a different wire gauge for the top loop if the resistance would be 0.1 Ohm instead of 6. I didn't dig into the supernode issue but instead wanted to help the OP to set up reasonable KCL equations instead of what came up in #12.
Yes, it's a good observation. The zero impedance branches can effectively cut the network in two. Of course i6 does effect i4 and i5, but nothing else. So superposition let's you solve the lower loops separately, with 2 nodes and two loops.
KVL #1) ## 4i_2 - 2i + 25 = 0 ##
KVL #2) ## 3i_3 - 4i_2 +5i = 0 ##
KCL #1) ## i + i_2 + i_3 = 0 ##
I do feel a bit o:) from taking over the OP choice of nodes at ##v_1, v_2, v_3## instead of using the one at the bottom :smile:
How ?? "5i" is a current not a voltage
I find that the directions of these currents are strange and illogical
On what basis did you do it?
Explain that to me in detail
What is the actual, real, original path that the current is taking?
Depending on your assumptions
Node v2 does not receive any current
How do I apply the KCL law?
What path directions did you take to apply KVL?
Tell me more
Tell me more
Have learned about the concept of a "supernode"?
As I said in post #19: This network needs only one KCL equation and two constraint equations. The 3 nodes can be treated as one supernode.
Explain that to me visually
