Angle of a force when towing a suitcase
  • Thread starter Thread starter barney007
    Angle Force
A woman is towing a 20kg suitcase at a constant speed with a 35N force on a strap at an unknown angle from the horizontal, while facing a 20N frictional force. The angle of the strap to the horizontal is calculated to be 55.2 degrees using the equation Tcos(θ) = F. The normal force exerted by the ground on the suitcase is determined to be approximately 167.3N, derived from the vertical force balance equation. The discussion highlights the application of vector components to solve for both the angle and the normal force. The solutions provided are useful for similar physics problems involving forces and motion.
barney007
hi guys
ive got a problem where a woman is towing a 20kg suitcase at constant speed. She is pulling on a strap of unknown degrees from the horizontal. She pulls on the strap with a 35N force and the frictional force on the suitcase is 20N.
It asks for the angle that strap makes to the horizontal as well as the normal force the ground exerts on the suitcase.
Any clues
Thanx
ok guys, I've worked it out
ill post my solutions just incase anyone was interested or you have a similar question
for part a
It says its moving at constant velocity, therefore to overcome the 20N friction there must be a 20N force in the horizontal direction, therefore this allows us to use reverse cos(20/35). This gives an angle of 55.2 degrees.
part b
use component method in vectors to find the vertical force of the strap, which is 35sin(55.2). minus this from mg( which is equal to N) and this gets 167N
barney007 said:
hi guys
Any clues
Thanx
Let the unknown angle=@
H: Tcos@-F=0
=>Tcos@=F
=>35cos@=20
=>cos@=(20/35)=(4/7)
=>@=arccos(4/7)=55.2deg
V: Tsin@+N-mg=0
=>N=mg-Tsin@
=>N=20g-35sin55.2=167.3N
Dirac.
H: Tcos@-F=0
=>Tcos@=F
=>35cos@=20
V: Tsin@+N-mg=0
=>N=mg-Tsin@
Dirac.
Did you not read his second post? He worked out the solutions already..
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
