Angle, range and extension in projectile motion?
The discussion focuses on determining the relationships between launch angle, extension of a rubber band, and the range of a projectile launched from a trebuchet. The user has calculated the spring constant at 184 N/m and is using energy equations, specifically the conversion of elastic potential energy (EPE) to kinetic energy (KE), to analyze the motion. They reference the equation for range in projectile motion and emphasize the need for repeated tests to gather data for their investigation. Additionally, there is a consideration of how to incorporate gravitational potential energy into their calculations. The goal is to adjust the angle and extension to achieve a specific landing range for the projectile.
donkeycopter
We have a trebuchet which we can adjust the launch angle, and how far the rubber band is pulled back (extension). The rubber band spring constant is constant throughout. I need to find the relationship between the angle of launch and range, and the relationship between the extension and range. This should allow me to finally be given a range, and adjust the angle and extension so as to make the mass land at that spot.
We are given no equations, but I have been using the kinetic and gravitational potential energy equations.I have trial data in which I have calculated the spring constant - at 184 n/m.
I have calculated an equation which shows EPE = Fx/2 (the area under the trial data graph is EPE, as it is a force (F) vs extension (x) graph).
On the net I found the equation: u = \sqrt{Rg/2sin20}
R-range
g-gravityHow should I go about solving this? We need to collect data from repeated tests etc, its an investigation.
Thanks a lot! :)
The energy in the spring is 1/2kx2 which is converted into KE as the mass leaves the rubber band.
so you will have by conservation of energy 1/2kx2 = 1/2 mv2 with v being your initial velocity.
So I shouldn't get the speed at the top of the ramp, so it would be KE + MGH?
What else can I do?
