Angular momentum associated with a current carrying circular wire
The discussion centers on calculating the angular momentum associated with a current-carrying circular wire, exploring both the contributions from the electrons and the electromagnetic field. Participants examine the implications of angular momentum in the context of a wire connected to a DC source and its behavior in a magnetic field.
  • One participant proposes a formula for angular momentum based on the drift velocity of electrons, suggesting ##L = n m_e v_{drift} r##.
  • Another participant questions the meaning of "angular momentum" in this context and discusses the forces and torque on the coil in a magnetic field.
  • Some participants mention that there is angular momentum associated with both the electrons and the electromagnetic field, but seek ways to quantify it.
  • A participant describes the setup as a resistive wire in a circular shape connected to a DC source, noting that the loop will align with the magnetic field and may oscillate during this alignment.
  • There is a discussion about whether the loop carries angular momentum before the magnetic field is applied and how this relates to the behavior of the electrons in the wire.
  • One participant draws an analogy to classical electron motion around a nucleus, suggesting that the magnetic moment of the wire loop relates to the angular momentum of the current flowing through it.
  • A later post elaborates on the relationship between magnetic moment and angular momentum, providing a detailed derivation involving the drift velocity and the gyromagnetic factor.
Participants express differing views on the definition and implications of angular momentum in this context, with no consensus reached on how to quantify it or its significance in relation to the magnetic field.
Participants note the complexity of the setup, including the influence of damping and the absence of a commutator, which may affect the behavior of the loop in a magnetic field.
gurbir_s
How should I calculate the angular momentum carried by a current carrying circular wire? Is it correct to consider the angular momentum of the electrons moving with drift velocity? Like
##L = n m_e v_{drift} r## where ##r## is radius of the loop, and ##n## is total number of electrons moving in the wire?
Can you say more about your setup? You can calculate the forces and torque on such a current-carrying coil in the presence of a B-field, but what do you mean by "angular momentum" in this context? If the coil is free to spin up under the influence of the torque, the angular momentum will increase with time...
Also, is there a commutator in this setup (like with a DC motor)?
There's angular momentum of both the electrons and the electromagnetic field!
It is simply a resistive wire in the shape of a circle connected to a DC source.
Actually, I read somewhere that such a loop placed in a magnetic field will simply get aligned in the direction of field. But if it carried an angular momentum, it should have precessed around the applied field.
How to quantify it?
If it carried some angular momentum before the B-field is turned on? I'm still not understanding the question. The loop will experience a torque to try to align it with the B-field, and depending on the damping of the setup, will oscillate for several cycles during that alignment (when there is no commutator).
Yes. The angular momentum carried by the circular current carrying wire without applying any field.
Just like in the classical picture, the electrons revolving around nucleus, have an angular momentum and give rise to magnetic moment, by that analogy, since the wire loop has magnetic moment, I want to calculate the angular momentum associated with the current flowing through the wire.
Ah, so the angular momentum of the electrons in the conduction band moving at the drift current velocity induced by the voltage applied to the coil terminals...
https://en.wikipedia.org/wiki/Drift_velocity
Yes. Sorry, it took me so long to make the question clear.
However, I can't find any reference to the angular momentum in the above mentioned Wikipedia article.
Actually, the magnetic moment of the current loop can be seen as the magnetic momentum of the electrons moving around the loop with the drift velocity. If we consider a loop of radius R, made from wire with cross section S, we can start with the magnetic moment $$\mu=IA$$
and express the current, I, as ##I=nev_d S ## and the area of the loop as ##A=\pi R^2##. Considering that the volume of the wire is ##V_w= 2\pi R S##, we'll have$$ \mu=(nev_d a) (\pi R^2) = (2\pi R S) n \frac{e}{2m} (m v_d R) = N \frac{e}{2m}(m v_d R)$$ where N is the total number of electrons, ##N=n V_w## and ##\frac{e}{2m}## is the gyromagnetic factor for the orbital motion of the electrons.
So, it looks like ##\mu=\gamma N l## or ##\mu=\gamma L## where l is the angular momentum for one electron and L is for all of them.
  • · Replies 61 ·
