Angular Momentum commutation relationships
ognik
It seems to be implied, but I can't find it explicitly - the order in which linear operators are applied makes a difference. IE given linear operators A,B then AB is NOT necessarily the same as BA ? I thought it was only with rotation operators that the order made a difference?
I noticed this while looking at text that showed [Lx,Ly] = i(h-bar)Lz, using only position and momentum operators...<<mentor note: originally posted in homework forum, template removed>>
In general, linear operators will not commute. Another common example is the position and momentum operators.
Thanks - of course, not a clever question when I am studying commutation relationships... But now I might see what was bothering me (I think) - the text expands [Lx,Ly] in terms of position and momentum operators, you get 8 terms like YPzZPx - the last 4 could cancel the 1st 4 out - but only if it was OK to change the order - like ZPxYPz (which is the 1st of the last 4, to complete the example). So are they OK in assuming that the operators don't commute - in order to prove that other operators don't commute?
Yes. You can easily derive the commutation relations for ##P_i## with ##X_i## using the position basis representation ##P_i \to -i\partial_i## and ##X_i \to x^i## and their action on any wave function ##\psi(x)##.
If they don't commute yes... if they commute, no...
If they commute, you have to be careful when changing the order -> new terms can be brought in.
For example if I have x p_x and I want for some calculation to rewrite it in p_x x (because it would come handy) I would have to use the relation:
[x, p_x ] = x p_x - p_x x= i \hbar \Rightarrow x p_x = p_x x + i \hbar and that's with what you change x p_x.
Thanks all
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
If we release an electron around a positively charged sphere, the initial state of electron is a linear combination of Hydrogen-like states. According to quantum mechanics, evolution of time would not change this initial state because the potential is time independent. However, classically we expect the electron to collide with the sphere. So, it seems that the quantum and classics predict different behaviours!
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
