MHB How Do You Solve Combination Problems for the GRE?
  • Thread starter Thread starter greprep
    Combination
To solve combination problems for the GRE, it's essential to understand the principles of maximum and minimum overlap. In the given scenario, the maximum number of cars containing parts A and B is calculated by adding the individual totals of each part, resulting in 155. The minimum is determined by accounting for the overlap, which leads to a total of 147 when excluding the 8 cars that contain both parts B and C. Constructing a Venn diagram can help visualize the relationships and overlaps between the sets. This approach aids in accurately determining the total number of cars that contain part A, part B, or both.
greprep
Hi, All! Prepping for the GRE here and definitely notice a weakness in calculating potential combination questions. Any advice on how to solve the following type of problem quickly?
"An automotive manufacturer installed part A into 82 cars, part B into 73 cars, and part C into 25 cars. At least one of the cars contains both parts A and B, and exactly 8 cars contain both parts B and C. None of the cars contains both A, B, and C.
What are the total number of cars that contain part A, part B, or both? "
Mathematics news on Phys.org
Hello greprep and welcome to MHB! :D
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
Of course, thanks for your help.
I'm thinking that I would look for the max and min. Meaning, the maximum number of cars that have A or B are if there is no overlap, meaning 82 + 73. And the minimum, is if there is full overlap (excluding the fact that 8 have B and C), and we know that we can't have A, B, and C. Meaning, the minimum would be 82 + 73 - 8?
Can you construct a Venn diagram?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
