Another gravity wave question
  • Thread starter Thread starter jnorman
    Gravity Wave
jnorman
i have read quite a bit about gravity waves, and even worked (as a lab tech) on an early GW experiment at LSU back in the 70s. i have become ever more convinced that the search for GWs is relatively fruitless.
the reason i feel that way is that, given any particular example of an event which would cause GWs, such as exploding star or orbiting binary neutron stars, the center of gravity will not be changed, and local GWs will be smoothed out in very short distance (astronomically speaking).
for any GW to be actually noticeable or measureable at any astronomical distance, the center of gravity of some very massive system would need to be altered significantly, and frankly i can't even think of a single example of how that might occur.
perhaps one of you could please enlighten me on the error of my thinking on this. thanks.
It's true that the center of gravity can't change. That's why gravitational waves are quadrupole radiation, not dipole radiation.
The intensity (watts/m2) falls off as 1/r^2. It can't fall off faster than that because of conservation of energy.
This is all assuming that GR's description of gravitational waves is right. However, the extremely good agreement of the Hulse-Taylor pulsar's behavior with GR suggests that GR's description is right.
jnorman: I hope you are wrong. here is why: There is a satellite ystem that is supposed to be able to detect subtle differences between gravitational waves emanting from a big bang that will be slightly different than those emanting from a brane collision in a cyclic universe. That would be fun if it works!
I posted details in another thread based on information from THE ENDLESS UNIVERSE by Steinhardt and Turok and all I remember is that it had to do with the polarization of such waves. Ok it's dubbed the BBO or Big Bang Observatory...and is described in the book around page 218...
I'll see if I can find the prior thread...
Could not find it...anyway LIGO and LISA according to the above authors are not sensitive enough for the big bang, and... WMAP came up with nothing so far...but should be able to detect major collisions, like black holes, etc...
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
