Another practice question: nortons theorem
  • Thread starter Thread starter amy_a
    Theorem
This discussion focuses on Norton's Theorem, specifically how to determine the current through load resistor (RL), the voltage across RL, and the power developed in RL. The key equations mentioned include the Norton current calculation: I(Norton) = [E/(R1+(R2//R3))]*[(R2//R3)/R3]. Participants clarify that the double backslashes (//) denote a parallel resistor combination, and emphasize that all resistors except RL and R4 must be considered when calculating the short-circuit current. The discussion concludes with a structured approach to applying Norton's Theorem, including calculating short-circuit current and output resistance.
  • Understanding of Norton's Theorem
  • Familiarity with Thevenin's Theorem
  • Knowledge of resistor combinations, particularly parallel (//) and series
  • Basic electrical circuit analysis skills
  • Study the detailed procedure for applying Norton's Theorem
  • Learn about calculating short-circuit current in electrical circuits
  • Explore the relationship between Norton and Thevenin equivalents
  • Review resistor combination techniques, focusing on parallel and series calculations
Electrical engineering students, circuit designers, and anyone seeking to deepen their understanding of circuit analysis using Norton's Theorem.
amy_a
hi guys, sorry to be a bothersome newbie but i have another electrical query. this time its nortons theorem. i need to determine the current through RL, the voltage across RL and the power developed in RL using the theorem.
any pointers on where to start would be really appreciated :!)
R(Norton) = R (Thevenin).
Regards,
Nacer.
thanks nacer, i'd best get to work :)
ok forgive my naivety but what do the double backslashes indicate? // like that? i know the single one is divide. i feel really retarded now.
I think he is referring to a parallel combination, i.e R1//R2 = (R1*R2)/(R1+R2)
Norton equivalent is no different from Thevenin. Norton equi. = Current Source with a resistor in parallel and Thevenin has voltage source and resistor in series. So, basically you can apply your knowledge of Thevenin equivalents from antoher thread :biggrin: and then just replace a thevenin equ that you'll get with Nortons
thanks guys :) i appreciate it! can anyone tell me why r4 is not considered when calculating the current (using the equation given by nacer) would i just have to apply that formula to the diagram above to find the norton current?
Every resistor excluding Rl&R4 has to be considered, because you're looking for so-called short-circuit current, so when you have a direct connection between the RL terminals, where does the current go? Since the current is looking for the easiest path, the path with least resistance, it will go just via a direct connection, rather then going via R4.
Check out this link to get more info.
http://en.wikipedia.org/wiki/Norton's_theorem
I suggest that you read up on the Nortons procedure.
1. Calculate the short-circuit current by applying the direct connection between output terminals
2. Calculate output resistance by replacing the voltage source with a short-circuit
3. Norton-source = short-circuit current & Output resistance = resistance from step 2.
  • · Replies 55 ·
13K
  • · Replies 28 ·
  • · Replies 183 ·
70K
  • · Replies 62 ·
