How Far Did the Football Travel in Total Displacement?
  • Thread starter Thread starter soul814
    Vector
The discussion focuses on calculating the total displacement of a football during a play involving a quarterback's movements. The quarterback runs backward for 10 yards, then sideways for 15 yards, and finally throws a 50-yard forward pass. The initial calculation using the Pythagorean theorem suggested a resultant displacement of about 52 yards, but further analysis corrected this to approximately 43 yards. The correct approach involved adjusting the right triangle formed by the quarterback's movements to accurately determine the resultant displacement. The final consensus confirms the magnitude of the football's resultant displacement is around 43 yards.
soul814
another vector problem (check if I'm correct)
A quarterback takes the ball from the line of scrimmage, runs backward for 10.0 yards, then runs sideways parallel to the line of scrimmage for 15.0 yards. At this point, he throws a 50 yard forward pass straight downfield, perpendicular to the line of scrimmage. What is the magnitude of the football’s resultant displacement?
Is it about 52? Since I used a^2 + b^2 = c^2
50^2 + 15^2 = c^2
the figure i get in my head is something like
A |...
...|...|C
B |___|D
AB = 50
CD = 10
BD = 15
u are supposed to find AC
-- AI
ahh after looking at your diagram it should be
40^2 + 15^2 = c^2
about 43 then
yeap!
-- AI
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
