hotvette said:You have an equation of a parabola and 3 points. From this you can find expressions for a, b, and c. Substituting the values for a and c into the first equation will yield the second equation.
Curd said:so i was right? i just need to change the first equation into ax squared+ bx + c form?
Mark44 said:In addition to what hotvette and Mentallic said, the problem is equivalent to showing that 2ah2 + 6c = y0 + 4y1 + y2.
Use the formula for the parabola and the three points that are given to find y0, y1, and y2, and then show that the equation above follows.
It's probably the most obvious thing to start with.Curd said:the whole stupid thing was just a substitution issue? ( y of -h for y2, y of 0 for y1 and y of h for y2)
how do you know to substitute?
Mark44 said:It's probably the most obvious thing to start with.
You're given:
1) the equation of the parabola: y = ax2 + bx + c
2) three points on the graph of this parabola: (-h, y0), (0, y1), and (h, y2)
3) A formula for the area between the x-axis and the parabola, between x = -h and x = h: A = (h/3)(2ah2 + 6c)
You're asked to show that the expression for area above can be written in another expression that involves y0, y1, and y2.
A natural thing to try would be to substitute the three given points into the equation for the parabola, and see what happens when you do that.
On the other hand, part of these kinds of problems is to take the information that is given, and figure out what you need to do with it to arrive at the solution.Curd said:didn't seem real natural to me. i wish they would have explained the problem a bit better.
Mark44 said:On the other hand, part of these kinds of problems is to take the information that is given, and figure out what you need to do with it to arrive at the solution.
What jargon? The language that was used seemed to me to be ordinary, simple English. Can you give an example of what you considered to be jargon?Curd said:I tend to expect such a thing to be true of the problem that is represented by the language of mathematics, but not to be true of the language itself.
in other words, this problem was an issue of understanding their jargon, for lack of a better word than jargon at the moment, rather than a mathematical concept. When I'm presented with a problem i tend to expect it to be about understanding a mathematical concept and not the particular jargon used.
What notations are you talking about?Curd said:this wasn't even an issue of understand a relationship between equations. it was more of an issue of understanding the relationship of the notations they were using. it was kind of a cheap shot on their part.
Mark44 said:What jargon? The language that was used seemed to me to be ordinary, simple English. Can you give an example of what you considered to be jargon?
This is not jargon. All they are doing here is using subscripts to identify three different y values. You can see from the graph in the problem statement that these are three different y values.Curd said:they used y0 to mean y of -h or y(-h) or f of -h or f(-h)... however you wish to write it.
they used y1 to mean y of 0 or y(0) or f of 0 or f(0)... however you wish to write it.
they used y2 to mean y of h or y(h) or f of h or f(h)... however you wish to write it.
As already noted, since they didn't define a function f, it would have been meaningless to talk about values of a function that hadn't been defined.Curd said:the fact that realizing that was the crux of the problem, even to the point of being the problem itself means that this problem was not about math but about figuring out what they meant when they used the "jargon, for lack of a better term, y1 y0 and y2.
i've never seen y's used like that before.
had they written it as
A= h/3 ( f(-h) + f(0) + f(h) )
Curd said:it would have made much more sense.
Mark44 said:This is not jargon. All they are doing here is using subscripts to identify three different y values. You can see from the graph in the problem statement that these are three different y values.
The equation of the parabola was not defined in function notation, meaning it was not defined as f(x) = ax2 + bx + c, so f(-h), f(0), and f(h) would not be meaningful in this problem.
Actually, they didn't define any function f. If they had, what you posted would have said f(x) = ax2 + bx + c. Certainly y is a function of x, as shown in this equation, but there is no mention of a function named f or g or any of the letters usually used for function names.Curd said:acutally, they did define the function of f. they say plain as day that the graph is of
y= ax squared + bx + c
What do you do when you are given an equation such as t = f(y)?Curd said:sorry, i didn't get what you said at first.
this reminds me of way back when i always rewrote f(x) as y. so the whole issue was that i didn't realize that we were replacing f(x) with y, right?
Mark44 said:Actually, they didn't define any function f. If they had, what you posted would have said f(x) = ax2 + bx + c. Certainly y is a function of x, as shown in this equation, but there is no mention of a function named f or g or any of the letters usually used for function names.
Mark44 said:What do you do when you are given an equation such as t = f(y)?
You said earlier that, whenever you used to see f(x), you replaced it with y. What I meant by this question was, what do you replace f(y) with?Curd said:go find the equation f. then plug y into it to see if i can get t?
Mark44 said:You said earlier that, whenever you used to see f(x), you replaced it with y. What I meant by this question was, what do you replace f(y) with?
Where I was going with this was to caution you about doing too many things on autopilot, without thinking.
