Anyone know how does the stealth technology work?
  • Thread starter Thread starter vincent81
    Technology Work
Stealth technology primarily relies on specific geometric designs that reflect radar waves away from their source, allowing aircraft like the F-117 and B-2 bombers to evade detection. The F-117 employs angled surfaces to achieve this, while the B-2 uses a technique known as continuous curvature, which enhances radar evasion. Stealth does not render aircraft invisible but reduces their radar signature, enabling them to navigate through gaps in radar coverage created by overlapping radar defenses. Research is also ongoing into stealth suits designed to make soldiers less detectable, utilizing pinhole cameras to project images from the environment. However, these prototypes have limitations, such as low resolution and heat signature issues. The Philadelphia Experiment, a controversial topic, suggests the use of magnetic fields to bend light around objects, but remains largely regarded as a conspiracy theory.
vincent81
Computer science news on Phys.org
im assuming your talking about the stealth bombers and such. Wot happens is they found out that certain angles reflect radar waves (witch work similar to sonar). So the idea is to create an air craft that has a geometry that allows it to reflect radar away from the source while still allowing it to be arodynamic enough to fly. This is how its done in the F-117. In the B-2 bomber they use a technology called continuous curvature. I am not really sure how that works. However, stealth tech does not make them invisible to radar. Wot it does is reduce the effective range of radar. When other countries "lay down" rader defences they have them overlap a little bit. But since there is stealth, it allows a plane the traverse through "gaps" in the radar coverage that don't exist for other planes.
...if that made no sense i made a rough diagram as to wot I am talking about.
i was referring to US research on stealth suit to make their troops invisible.
what makes something invisible?
Is invisibility possible?
o ok, my bad. yeah, they have been doing research into a suit that has pin hole cameras pointing out and then projects the image it sees on the other side. There are obvious flaws to this idea. There was a working prototype, however, it was very very low res with a pixle a couple of inched in diameter. the effect that was created was slightly better than that of camo fatigues. Though, you still need to address the heat generated from both the body and the suit. I heard about something called the Philadelphia experiment. THe idea (or controversy) was to use magnetic fields to warp light around the ship effectivly creating a "bubble" in witch no light got in or out. but that's just a conspiracy.
This week, I saw a documentary done by the French called Les sacrifiés de l'IA, which was presented by a Canadian show Enquête. If you understand French I recommend it. Very eye-opening. I found a similar documentary in English called The Human Cost of AI: Data workers in the Global South. There is also an interview with Milagros Miceli (appearing in both documentaries) on Youtube: I also found a powerpoint presentation by the economist Uma Rani (appearing in the French documentary), AI...
I have been idly browsing what Apple have to offer with their new iPhone17. There is mention of 'Vapour cooling' to deal with the heat generated. Would that be the same sort of idea that was used in 'Heat Pipes' where water evaporated at the processor end and liquid water was returned from the cool end and back along a wick. At the extreme high power end, Vapour Phase Cooling has been used in multi-kW RF transmitters where (pure) water was pumped to the Anode / or alternative Collector and...
