Anyone Know How To Use This Data To Classify A Star From 0 - M?
  • Thread starter Thread starter hype_chicky
    Data Star
To classify a star from 0 - M, analyze the data in Tables 1 and 2 to identify the elements and ions based on their wavelengths and associated errors. For instance, Star 1 contains Hydrogen, Calcium, and Sodium, while Star 2 includes Hydrogen, Helium, and Sodium. Comparing these wavelengths to known spectral class values helps determine the classification, such as identifying strong Hydrogen lines for type A stars or Helium lines for type B stars. It's crucial to verify the data due to potential discrepancies. This method allows for accurate classification of stars based on their spectral characteristics.
hype_chicky
RESULTS
Table 1: The following table demonstrates the results obtained for Star 1
Line # Wavelength Possible Element/Ion Error Mark-up(nm)
1 383.91 nm Hydrogen [H] + 0.41
2 388.60 nm Hydrogen [H] - 0.30
3 393.26 nm Calcium [Ca+] - 0.14
4 397.0 nm Hydrogen [H] 0
5 410.09 nm Hydrogen [H] - 0.10
6 434.4 nm Hydrogen [H] + 0.30
7 486.36 nm Hydrogen [H] + 0.26
8 589.15 nm Sodium [Na] + 0.05
9 656.3 nm Hydrogen [H] 0
Table 2: The following table demonstrates the results obtained for Star 2
Line # Wavelength Possible Element/Ion Error(nm)
1 369.2 nm - -- - - -
2 375 nm - - - - - -
3 378 nm - - - - - -
4 381 nm - - - - - -
5 383.36 nm Hydrogen [H] - 0.24
6 389.26 nm Hydrogen [H] + 0.36
7 393.9 nm Calcium [Ca+] + 0.5
8 397.4 nm Hydrogen [H] + 0.4
9 402.42 nm Helium [H] - 0.18
10 409.8 nm Hydrogen [H] - 0.40
11 419.94 nm Helium [H+] - 0.06
12 434.1 nm Hydrogen [H] 0
13 446.9 nm Helium [He] - 0.20
14 454.42 nm Helium {He+] + 0.32
15 468.58 nm Helium {He+] - 0.02
16 486.1 nm Hydrogen [H] 0
17 541.38 nm Helium [He+] +0.28
18 589.04 nm Sodium [Na] + 0.04
19 627.7 nm - - - - - -
20 686.7 nm - - - - - -
To classify a star from 0 - M, you can use the data provided in Table 1 and Table 2. The first step would be to identify the possible elements/ions present in each star based on the wavelength and error values. For example, in Star 1, we can see that there is Hydrogen, Calcium, and Sodium present. In Star 2, there is Hydrogen, Helium, and Sodium present.
Next, you can compare the wavelengths and errors of the lines in each star to known values for different spectral classes. For example, a star with strong Hydrogen lines at 656.3 nm and 486.1 nm would be classified as a type A star. Similarly, a star with strong Helium lines at 402.42 nm and 468.58 nm would be classified as a type B star.
By analyzing the data and comparing it to known spectral class values, you can classify the stars from 0 - M. It is important to note that there may be some discrepancies or errors in the data, so it is always best to double check and verify your classification.
In summary, to classify a star from 0 - M, you can use the data provided in Tables 1 and 2 to identify the possible elements/ions present and compare the wavelengths and errors to known spectral class values.
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
