Apparent depth of an object underwater
The discussion focuses on determining the apparent depth of an object underwater using Snell's law and the approximation for small angles. The initial challenge involves finding the angles and the point along the water's surface where light exits to reach an observer's eye. After some calculations, the user arrives at a solution with the distance from the left corner being approximately 18 meters and an apparent depth of about 0.19 meters. The final confirmation indicates that the calculations are correct. This highlights the application of Snell's law in practical scenarios involving light refraction.
lorenz0
A person (the arrow at the upper left of the figure) of height ##h=1.7m## is standing at the edge of a pool of water of depth ##d=1.8m## in which there is an object located at the farthest end of the pool (black ball in the figure). What is the apparent depth of this object for the person looking at the pool, i.e. what is the depth of the object observed by the person (red ball in the figure)?
##n_1 \sin(\theta_1)=n_2\sin(\theta_2)##
I would know how to solve this problem if the person had been standing pratically above of the object underwater by using Snell's law and the approximation ##\sin(\theta)\approx\tan(\theta)## fopr ##\theta## small, but in this case I don't see how to find the angles ##\theta_1## and ##\theta_2## and, above all, at what point along the surface of the water the light with come out in such a way as to reach the eye of the person. Without this last information, when I try to set up Snell's law I get (with ##x## representing the distance from the left corner at which the light comes out): ## \frac{d^2+(L-x)^2}{d'^2+(L-x)^2}=1.33^2 ## but I have too many variables.
So, I would appreciate if someone could point me twoards a viable strategy to solve this problem. Thanks
Find the two angles as functions of x.
Thanks. I got ##x\approx 18\ m## and an apparent depth of ##d'\approx 0.19\ m##.
That looks right.
The book claims the answer is that all the magnitudes are the same because "the gravitational force on the penguin is the same". I'm having trouble understanding this. I thought the buoyant force was equal to the weight of the fluid displaced. Weight depends on mass which depends on density. Therefore, due to the differing densities the buoyant force will be different in each case? Is this incorrect?
15K
