Application of Cauchy's residue theorem
lyranger
Really need help for this one. Cheers!
Question: calculate function z/(1-cos z) integrated in ac ounterclockwise circular contour given by |z-2pi|= 1
Clearly the pole in the given contour is 2pi. But the problem is: if it's a simple pole, then apply formula
we have Residue=lim (z-2pi) * z/(1-cos z) where z->2pi. This limit does not exist.
So I reckon 2pi might be a higher order pole but this actually makes no sense and even if it's true,
there is a really nasty differentiation.
Any thoughts.?
Please use the standard format of PF!
Yes, please use LaTeX.
What you need is a Laurent expansion around the pole at z=2 \pi. For your function
f(z)=\frac{z}{1-\cos z}
you have
1-\cos z=\frac{(z-2 \pi)^2}{2}+\mathcal{O}[(z-2 \pi)^4].
You need the single-order pole contribution. You can get this by either using the standard formula
\text{res}_{z \rightarrow 2 \pi} f(z)=\lim)_{z \rightarrow 2 \pi} \frac{\mathrm{d}}{\mathrm{d} z} (z-2 \pi)^2 f(z),
which is a bit cumbersome here, or you use the series expansion of 1-\cos z as given above and use z=(z-2 \pi)+2 \pi in the numerator.
Likes 1 person
sorry for not using LaTex, haven't used this forum in ages.
And thanks so much for the help! very smart move!
Correct me if I am wrong, the answer is 4i*pi?
Looks good!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
