Application of derivatives problem?
The discussion revolves around a problem involving the calculation of calories burned by a salmon swimming upstream against a current. The energy equation provided requires the use of derivatives to minimize calories burned while swimming a distance of 20 miles at a current speed of 2 mph. Participants express confusion about how to properly apply derivatives to the energy equation and the time equation. Suggestions include finding the critical value of the swimming speed to determine the optimal time for the journey. The conversation emphasizes the importance of correctly interpreting the equations and using parentheses for clarity.
mirs
A biologist determines experimentally that the number of calories burned by a salmon swimming a distance d in miles upstream against a current v0 in miles per hour is given by
Energy = kdv^5/v − v0
where v is the salmon’s swimming speed relative to the water it is in. This means that the salmon’s progress upstream is at the rate of v − v0 miles per hour, so that the distance d is covered in a time of
t=d/v − v0
If v0 = 2 mph and d = 20 miles, and the salmon, being smart, swims so as to minimize the calories burned, how many hours will it take to complete the journey?
Requires derivatives
I really just don't understand where to start. I subbed t into the equation and ended up with ktv^5/v-v0, took the derivative of that with respect to t and got 5kv^4 but I have no idea what I really don't know where to go from there.
Do you mean ##\frac{kdv^5} v - v_0##, which is what you wrote, or ##\frac{kdv^5}{v − v0}##?
t=d/v − v0
Same problem here. Obviously you mean ##\frac d {v-v_0}##. Use parentheses!
Try finding the critial value of ##v## using the energy equation. Then use that to get the time of travel.
Yes! I meant (kdv^5)/(v−v0).
OK, so I'm guessing I don't plug t into the energy equation in the first place? because I did that and found the derivative to be 5ktv^4
Why are you guessing? Why not just try what I suggested?
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 17 ·
