Why is the Electric Field Constant Along a Charged Cylinder's Surface?
The electric field along the surface of a uniformly charged cylinder is constant due to the symmetry of the charge distribution. Gauss's law is applicable, primarily for infinitely long rods, but it provides a good approximation for finite lengths if the observation point is far from the ends. The electric flux through the caps of the Gaussian surface is zero because the electric field lines are parallel to these surfaces, resulting in no contribution to the flux. This uniformity in electric field intensity is a key characteristic of cylindrical symmetry. Understanding these principles is essential for accurately applying Gauss's law in electrostatics.
Godwin Kessy
Am really suprised when deriving electric field due to a uniform charged thin long rod! It was suprising to have a cylinder as a gausian surface!
actualy is that posible, that all along the surface of the cylinder has same field intensity and why?
also why are there no electric flux along the caps of the gausian surface "the cylinder"
Technically, Guass' law only works for an infinitely long rod. If the rod is shorter than infinity, Guass' law is just an approximation. But it makes a pretty good approximation if you are not dealing with anything close to the edge of the rod, and you are much closer to the rod than the rod is long.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
Thread 'Recovering Hamilton's Equations from Poisson brackets'
The issue : Let me start by copying and pasting the relevant passage from the text, thanks to modern day methods of computing. The trouble is, in equation (4.79), it completely ignores the partial derivative of ##q_i## with respect to time, i.e. it puts ##\partial q_i/\partial t=0##. But ##q_i## is a dynamical variable of ##t##, or ##q_i(t)##. In the derivation of Hamilton's equations from the Hamiltonian, viz. ##H = p_i \dot q_i-L##, nowhere did we assume that ##\partial q_i/\partial...
