Applications of Differentiation
The discussion revolves around a mathematical model predicting vehicle traffic in a tunnel after a fee increase. The model, N(t) = 40 / (1 + be^(-rt)), requires determining constants b and r based on observed traffic changes: dropping to 16 thousand vehicles after one week and increasing to 17.4 thousand by the end of the second week. Participants confirm that N(t) is increasing and discuss how to find the average number of vehicles, Na, as time progresses. The expert suggests advertising when the rate of increase in traffic is maximized, which is determined by setting the second derivative N''(t) to zero. The optimal advertising day is calculated to be the 20th day after the fee increase.
chrisyuen
A vehicle tunnel company wants to raise the tunnel fees. An expert predicts that after the increase in the tunnel fees, the number of vehicles passing through the tunnel each day will drop drastically in the first week and on the t-th day after the first week, the number N(t) (in thousands) of vehicles passing through the tunnel can be modeled by N(t) = 40 / (1+be^(-rt)) (t>=0) where b and r are positive constants.
(a) Suppose that by the end of the first week after the increase in the tunnel fees, the number of vehicles passing through the tunnel each day drops to 16 thousand and by the end of the second week, the number increases to 17.4 thousand, find b and r correct to 2 decimal places.
(b) Show that N(t) is increasing.
(c) As time passes, N(t) will approach the average number Na of vehicles passing through the tunnel each day before the increase in the tunnel fees. Find Na.
(d) The expert suggests that the company should start to advertise on the day when the rate of increase of the number of cars passing through the tunnel per day is the greatest. Using the values of b and r obtained in (a),
(i) find N''(t), and
(ii) hence determine when the company should start to advertise.
((d)(ii) 20th day)
Differentiation Rules
I don't know how to solve the part (d)(ii) of the question.
I think I should set the N''(t) = 0 in order to get the t.
But can anyone tell me why should I set N''(t) = 0?
Thank you very much!
((d)(ii) 20th day)
" The expert suggests that the company should start to advertise on the day when the rate of increase of the number of cars passing through the tunnel per day is the greatest."
You find an extremum of a function by setting its derivative to 0. You are trying to find when "the rate of increase" is greatest- that is, you are trying to find when N'(t) is greatest and that happens when (N')'= N"= 0.
I got it!
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
