A Can the Fejér Kernel Be Approximated by Polynomials?
The Fejér kernel can be approximated by polynomials through methods such as rewriting it as a sum of exponentials, which are easily approximated using their series expansions. Additionally, the Stone-Weierstrass theorem provides a framework for polynomial approximation of continuous functions. These approaches confirm that polynomial approximations of the Fejér kernel are feasible. Understanding these methods can enhance the study of the kernel's properties. Overall, polynomial approximation is a valid technique for analyzing the Fejér kernel.
Vannel
TL;DR Summary
Methods to approximate Fejér kernel
Hello, I'm currently studying the Fejér kernel, which has the form of
F_{n}(x)={\frac  {1}{n}}\left({\frac  {\sin {\frac  {nx}{2}}}{\sin {\frac  {x}{2}}}}\right)^{2}={\frac  {1}{n}}\left({\frac  {1-\cos(nx)}{1-\cos x}}\right)
. I want to know whether there are some methods to approximate this function into polynomials.
Thanks a lot for the help!
Mathematics news on Phys.org
Take a look here:
https://en.wikipedia.org/wiki/Fejér_kernel
We can rewrite the kernel as a sum of exponentials, and exponentials are easily approximated by polynomials (take some terms of their series expansion). Thus we can approximate the kernel as well.
Alternatively, you can use results like Stone-Weierstrass.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
