Are equivalent resistances wrong in this circuit analysis?
11 replies · 4K views · last reply
Hidd
Thread moved from the technical forums, so no Homework Template is shown
Hello!
I've took a course about Electrical circuits and Networks at the university, and i found out a problem which is uploaded by my professor, and i think he made a mistake!
Fig. 3.2: square resistor network with corners A, B, C, D and resistors labelled R on each side and both diagonals, shown beside Fig. 3.3, a crossed-diagonal star-style arrangement with terminals A, B, C, D and resistors R_AO, R_BO, R_CO, R_DO.
this is the solution
Typed solution of a bridge resistor network: RAB = R||Rbridge, equilibrium condition R/R = R/R, Rbridge = 0.5R = 25 ohms, then six node-pair resistances RAB, RAC, RAD, RBC, RBD, RCD each written as a sum of two star-branch resistances equal to 0.5R.
i think that the equivalent resistances are wrong (beside Rab), for example if you look at Rcd it must be 0, because it's short circuited.
And i coudn't find "the bridge" that he mentioned.
Thanks for help!
All the best,
  • Fig. 3.2: square resistor network with corners A, B, C, D and resistors labelled R on each side and both diagonals, shown beside Fig. 3.3, a crossed-diagonal star-style arrangement with terminals A, B, C, D and resistors R_AO, R_BO, R_CO, R_DO.
  • Typed solution of a bridge resistor network: RAB = R||Rbridge, equilibrium condition R/R = R/R, Rbridge = 0.5R = 25 ohms, then six node-pair resistances RAB, RAC, RAD, RBC, RBD, RCD each written as a sum of two star-branch resistances equal to 0.5R.
Note that there is no connection "dot" where those wires cross :wink: Every other junction has a dot.
gneill, Thank you for your reply and i think you're right! but what about the "bridge"?
we worked on "Wheatstone bridge" which looks like that:
https://www.electronics-tutorials.ws/wp-content/uploads/2013/10/wheatstone1.gif
but i couldn't find similarities with the one that i mentioned earlier!
You may need to re-draw your circuit (rearrange the diagram) in order to be able to visualize the bridges. For example, if you remove the resistor that connects node A to node B, then you have:
Circuit schematic with nodes A, B, C and D and resistors R2 to R6; R2 runs from A to C, R5 from B to D, R6 between C and D, and R3 and R4 cross each other diagonally between the two upper junctions and nodes D and C.
Which can be rearranged as:
Circuit schematic of a resistor bridge between terminals A and B, with resistors R2 and R3 in the left branch, R4 and R5 in the right branch, and R6 as the bridge between nodes C and D.
Note that the same resistors still connect to nodes with the same labels; the topology of the circuit is the same as before. Now can you "see the bridge"?
  • Circuit schematic with nodes A, B, C and D and resistors R2 to R6; R2 runs from A to C, R5 from B to D, R6 between C and D, and R3 and R4 cross each other diagonally between the two upper junctions and nodes D and C.
  • Circuit schematic of a resistor bridge between terminals A and B, with resistors R2 and R3 in the left branch, R4 and R5 in the right branch, and R6 as the bridge between nodes C and D.
You can think of ABCD as a tetrahedron, with resistance R on each of the edges.
I was having a hard time drawing one, so I found an image of one.
Wireframe tetrahedron in pink with vertices labelled A at the top, B on the right, C on the left and D at the bottom front.
Then you can look at it from above A, and project it flat, so A is in the center of the triangle, and it connects outward to B C and D.
  • Wireframe tetrahedron in pink with vertices labelled A at the top, B on the right, C on the left and D at the bottom front.
For extra credit. what is the resistance seen by the source Uo in Fig. 3.1 if ALL (including Rd) of the resistors are 50 ohms?
@The Electrician. Can I get extra credit for clarifying the diagram and setting the source to one amp ?
LTspice schematic of a resistor network driven by a 1.0A current source I1, with nodes labelled A to E, resistors R1 to R11 each marked {r}, node voltages 97.826087V, 82.608696V, 78.260872V, 71.739128V and 50.000V, directive .tran 1m, and .param r = 50R.
  • LTspice schematic of a resistor network driven by a 1.0A current source I1, with nodes labelled A to E, resistors R1 to R11 each marked {r}, node voltages 97.826087V, 82.608696V, 78.260872V, 71.739128V and 50.000V, directive .tran 1m, and .param r = 50R.
For doubleplusgood credit, calculate the resistance from every node to every other node. First number all the nodes in the original network.
Resistor network diagram with nodes numbered 1 to 7 in red, all resistors labelled R; node 1 top left, node 2 top right, nodes 3 and 4 middle, nodes 5 and 6 bottom, node 7 at the bottom left end of a lead.
Then do the math:
Mathematica notebook screenshot: admittance matrix Y as a 7x7 matrix scaled by 1/50, its pseudoinverse Z shown as a fraction matrix, and a 7x7 resistance matrix R with zeros on the diagonal and symmetric values such as 23.478261 and 97.826087.
In the final result matrix the resistance from node j to node k is given by the (j,k) element of the matrix. The resistance from node j to k is, of course, the same as the resistance from node k to node j, hence the matrix is symmetric. And we see all zeroes on the main diagonal because the resistance from a node to itself is zero.
  • Resistor network diagram with nodes numbered 1 to 7 in red, all resistors labelled R; node 1 top left, node 2 top right, nodes 3 and 4 middle, nodes 5 and 6 bottom, node 7 at the bottom left end of a lead.
  • Mathematica notebook screenshot: admittance matrix Y as a 7x7 matrix scaled by 1/50, its pseudoinverse Z shown as a fraction matrix, and a 7x7 resistance matrix R with zeros on the diagonal and symmetric values such as 23.478261 and 97.826087.
The Electrician said:
For doubleplusgood credit, calculate resistance from every node to every other node...
Then do the math:
I am now curious, since I just went through a Linear Algebra course: what is the key to creating the Admittance matrix by inspection?
