Are equivalent resistances wrong in this circuit analysis?
11 replies · 4K views
Hidd
Thread moved from the technical forums, so no Homework Template is shown
Hello!
I've took a course about Electrical circuits and Networks at the university, and i found out a problem which is uploaded by my professor, and i think he made a mistake!
this is the solution
i think that the equivalent resistances are wrong (beside Rab), for example if you look at Rcd it must be 0, because it's short circuited.
And i coudn't find "the bridge" that he mentioned.
Thanks for help!
All the best,
Note that there is no connection "dot" where those wires cross :wink: Every other junction has a dot.
gneill, Thank you for your reply and i think you're right! but what about the "bridge"?
we worked on "Wheatstone bridge" which looks like that:
https://www.electronics-tutorials.ws/wp-content/uploads/2013/10/wheatstone1.gif
but i couldn't find similarities with the one that i mentioned earlier!
You may need to re-draw your circuit (rearrange the diagram) in order to be able to visualize the bridges. For example, if you remove the resistor that connects node A to node B, then you have:
Which can be rearranged as:
Note that the same resistors still connect to nodes with the same labels; the topology of the circuit is the same as before. Now can you "see the bridge"?
Yep! now i see it, Thank you very much gneill.
You can think of ABCD as a tetrahedron, with resistance R on each of the edges.
I was having a hard time drawing one, so I found an image of one.
Then you can look at it from above A, and project it flat, so A is in the center of the triangle, and it connects outward to B C and D.
For extra credit. what is the resistance seen by the source Uo in Fig. 3.1 if ALL (including Rd) of the resistors are 50 ohms?
@The Electrician. Can I get extra credit for clarifying the diagram and setting the source to one amp ?
For doubleplusgood credit, calculate the resistance from every node to every other node. First number all the nodes in the original network.
Then do the math:
In the final result matrix the resistance from node j to node k is given by the (j,k) element of the matrix. The resistance from node j to k is, of course, the same as the resistance from node k to node j, hence the matrix is symmetric. And we see all zeroes on the main diagonal because the resistance from a node to itself is zero.
The Electrician said:
For doubleplusgood credit, calculate resistance from every node to every other node...
Then do the math:
I am now curious, since I just went through a Linear Algebra course: what is the key to creating the Admittance matrix by inspection?
