Are 'power', 'index' and 'exponent' exact synonyms
The terms "power," "index," and "exponent" are related but not exact synonyms; "exponent" is more formal, while "index" is used differently in British and American contexts. "Exponential growth" specifically refers to functions of the form a^x, while x^a represents polynomial, rational, radical, or transcendental functions depending on the value of a. The operation of raising a number to another is called exponentiation, and it can be used generally, not just for e or specific bases. In modeling, functions like f(x) = Cx^a are referred to as power laws. The distinctions clarify the terminology used in mathematics.
Aeneas
Can you please help me sort out my terminology?
Are 'power', 'index' and 'exponent' exact synonyms, even thogh they tend to be used in different contexts? If a^x gives 'exponential growth' is the growth described by x^a also properly called 'exponential'? If not, what is it called?
Thanks,
Aeneas
Mathematics news on Phys.org
I would consider "power" and "exponent" to be basically the same- "exponent" being a little more formal than "power". Our British friends use "index" to mean "exponent" but we Americans do not. To us an "index" is simply a "label" (as on a vector or tensor) and can be either a superscript of a subscript.
"Exponential growth" on the other hand refers to the "exponential function", ex or variations on that such as ax= ex ln(a). Something like xa is a "polynomial function" if a is a positive integer, a "rational function" if a is a negative integer, a "radical function" if a is a fraction, and a "transcendental function" if a is irrational.
Note:
Often, in modelling, to utilize a function:
f(x)=Cx^{a}
is called to use a "power law". (C, a constants to be empirically determined).
Yes that's the way I refer to them.
f(x) = a^x : an exponential.
f(x) = x^a : a power (of x).
Thanks for those replies. Can you use "exponentiation" as a noun, to go with "addition" and "multiplication" for example, to generally describe the general process of raising one number to the power of another, then, or should it be reserved for raising e or some other number to the power of x?
Also, the phrase "exponential growth" is a common one, but what would you put in the bracket in "( ) growth" if the growth was described by, say, a polynomial function?
These are the distinctions as I know them:
A "power" is an operation also known as exponentiation, as in the third power of 2 is 8.
The "exponent" is the argument in the superscript of a power - then n in an. It is also the "index" of the power in the same way as n is the index of the radical \sqrt[n]{a}.
For a constant:
f(x) = a^x is an exponential function.
g(x) = x^a is a power function.
I hope this helps.
--Elucidus
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
