Area bounded by a curve and arbitrary line
PhizKid
Find the values of m for y = mx that enclose a region with y = \frac{x}{x^2 + 1} and find the area of this bounded region.
So I set the two functions equal to each other to solve for x in terms of m:
mx = \frac{x}{x^{2} + 1} \\\\<br /> mx(x^{2} + 1) = x \\\\<br /> mx^{3} + (m - 1)x = 0 \\\\<br /> x(mx^{2} + (m - 1)) = 0 \\\\
So when x = 0 and:
mx^{2} + m - 1 = 0 \\\\<br /> x = \sqrt{\frac{m - 1}{m}}
Now to solve for m, replace mx = \frac{x}{x^{2} + 1} with x = \sqrt{\frac{m - 1}{m}}:
m\sqrt{\frac{m - 1}{m}} = \frac{\sqrt{\frac{m - 1}{m}}}{\frac{m - 1}{m} + 1} \\\\<br /> m = \frac{1}{\frac{m - 1}{m} + 1} \\\\<br /> m - 1 + m = 1 \\\\<br /> 2m = 2 \\\\<br /> m = 1
So at y = 1x or y = x, it intersects the graph y = \frac{x}{x^2 + 1} exactly. Looking at the graph, if the slope is less steep, it looks like it will create a region. I don't know how to mathematically show this. So I would guess between 0 < m < 1 (not inclusive I guess?) it will create a region. And for the area, the integral I set up is:
2 \cdot \int_{0}^{\sqrt{\frac{m - 1}{m}}} (\frac{x}{x^{2} + 1} - mx) dx
Because it's symmetrical I guess. Evaluating:
2 \cdot \int_{0}^{\sqrt{\frac{m - 1}{m}}} (\frac{x}{x^{2} + 1} - mx) dx \\\\<br /> ln(x^2 + 1) - [m(x^{2} + 1)] \\\\<br /> ln(\frac{m - 1}{m} + 1) - [m(\frac{m - 1}{m} + 1)]
So the area is:
ln(\frac{m - 1}{m} + 1) - 2m + 1 for 0 < m < 1
Not sure where I went wrong here.
Your process is right but you went wrong almost immediately. Yes, an area is enclosed only when 0&lt;x&lt;1. When I solved for m, here is what I got:
mx=\frac{x}{x^2+1}
m=\frac{1}{x^2+1}
m(x^2+1)=1
x^2+1=\frac{1}{m}
x^2=\frac{1}{m}-1
x^2=\sqrt{\frac{1}{m}-1}
From there, proceed the exact way you did and you should get the following solution for the area:
ln(\frac{1}{m})+m-1
mx=\frac{x}{x^2+1}
m=\frac{1}{x^2+1}
m(x^2+1)=1
x^2+1=\frac{1}{m}
x^2=\frac{1}{m}-1
ln(\frac{1}{m})+m-1
Okay, I see my algebra error, but after you get x=\sqrt{\frac{1}{m}-1}, how do you solve for the values of m and get the boundaries 0 < x < 1? I can't do it anymore after I've fixed my error..
PhizKid said:
how do you solve for the values of m ?
x^2=\frac{1}{m}-1 allows you to write an inequality for \frac{1}{m}-1. Simplify that, considering the cases m > or < 0 separately.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
