Array of underwater transducers for sound massage
The discussion revolves around the concept of creating an underwater sound massage system using an array of individually steerable transducers. The user seeks advice on selecting appropriate broadband transducers that can operate between 200 Hz and 30 kHz, with a sound intensity of around 60 dB, while also considering the need for small transducer sizes for effective beamforming. A participant suggests that high frequencies may not be effective for massage due to their dissipation in water and proposes a lower frequency range of 0.2-3 Hz instead. Concerns are raised about the impact of underwater sound arrays on marine life, highlighting the noise pollution caused by such technologies. The conversation reflects a blend of technical inquiry and environmental awareness regarding underwater acoustics.
lost_in_space
hello,
since a while my mind is caught by an idea. This idea is concerned with underwater sound massage system.
For this purpose i would like to build an array of underwater sound transducers, which can all be steered individually (to do a coarse beam forming).
However, since i am not an engineer it is difficult for me to evaluate which transducers are appropriate for the application i have in mind and would be very greatful if someone here could comment on my guesses:
I need a broadband transducer that is capable to produce sound waves in a very broad range (200 Hz - 30khz) and with sound intensity around 60 db. It may be also possible to use different transducers for low and high frequencies. However, in order to do beamforming at a frequency of 30kHz the distance of the transducers must be around 5 cm. thus the transducer sizes must be quite small. (the most appropriate transducers i found were from the company benthowave, can anyone comment on this)
I would be very greatful if anyone could comment on the spezifications i have in mind.
best regards,
lost_in_space
High frequencies tend to dissipate, both in the water and in the body. Therefore, high frequency massage is a bit of an oxymoron. So instead of 200-30K Hz, I would suggest 0.2-3 Hz.
Those frequencies are best though of as pistons displacing water, not as sonic transducers.
lost_in_space said:
hello,
For this purpose i would like to build an array of underwater sound transducers, which can all be steered individually (to do a coarse beam forming).However, since i am not an engineer it is difficult for me to evaluate which transducers are appropriate for the application i have in mind and would be very greatful if someone here could comment on my guesses:
best regards,
lost_in_space
Hi there. Did you ever get anywhere with you underwater acoustic sound array?
Of course, these arrays are used for sonar for military and also for fishfinders etc.
Poor creatures like whales have to endure our activities.
I know they exist, I guess I was just wondering if lost_in_space ever got his project off the ground. As for the animals, I agree with you. It must be worse than Times Square down there as for noise.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
