MHB [ASK]Solution Set of a Trigonometry Inequation
  • Thread starter Thread starter Monoxdifly
    Set Trigonometry
The discussion focuses on solving the trigonometric inequality $$2\sin^2x \geq 3\cos2x + 3$$ within the interval [0, 2π]. The correct approach leads to the critical values $$x = \frac{\pi}{3}, \frac{2\pi}{3}, \frac{4\pi}{3}, \frac{5\pi}{3}$$, resulting in the intervals $$[\frac{\pi}{3}, \frac{2\pi}{3}] \cup [\frac{4\pi}{3}, \frac{5\pi}{3}]$$. The error in the initial solution was neglecting the negative solutions when taking the square root, which led to missing intervals. The final correct intervals are $$[60°, 120°] \cup [240°, 300°]$$, indicating that the sum of the endpoints a + b + c + d is not among the original options. The discussion emphasizes the importance of considering both positive and negative solutions in trigonometric equations.
Monoxdifly
MHB
The set of real numbers x at the interval [0, 2π ] which satisfy $$2sin^2x\geq3cos2x+3$$ takes the form [a, b] ∪ [c, d]. The result of a + b + c + d is ...
a. 4π
b. 5π
c. 6π
d. 7π
e. 8π
What I've done thus far:
$$2sin^2x\geq3(cos2x+1)$$
$$2sin^2x\geq3(cos^2x-sin^2x+sin^2x+cos^2x)$$
$$2sin^2x\geq3(2cos^2x)$$
$$sin^2x\geq3cos^2x$$
$$\frac{sin^2x}{cos^2x}\geq3$$
$$tan^2x\geq3$$
$$tanx\geq\sqrt3$$
$$tanx\geq tan60°$$ or $$tanx\geq tan240°$$
Since the value of tangent become negative after 90° and 270° respectively, I assume that [a, b] ∪ [c, d] is [60°, 90°] ∪ [240°, 270°] thus a + b + c + d = 660° = $$3\frac23\pi$$, but it isn't in the options. Where did I do wrong? I'm sure I solved the inequation alright and just blundered in determining the intervals, but how should I fix them?
Mathematics news on Phys.org
dividing by $\cos^2{x}$ was a mistake because $\dfrac{\pi}{2}$ and $\dfrac{3\pi}{2}$ are in the solution set$2\sin^2{x} \ge 3[\cos(2x)+1]$
$2\sin^2{x} \ge 3(1-2\sin^2{x} +1)$
$8\sin^2{x} \ge 6$
$\sin^2{x} - \dfrac{3}{4} \ge 0$
$\left(\sin{x}-\dfrac{\sqrt{3}}{2} \right) \left(\sin{x} + \dfrac{\sqrt{3}}{2} \right) \ge 0$
critical values are $x = \dfrac{\pi}{3}, \dfrac{2\pi}{3}, \dfrac{4\pi}{3}, \dfrac{5\pi}{3} $
inequality is true for $x$ in the intervals $\left[\dfrac{\pi}{3}, \dfrac{2\pi}{3} \right] \cup \left[\dfrac{4\pi}{3}, \dfrac{5\pi}{3} \right]$
Damn, I should've kept an eye on the denominator. Thanks for your guidance.
Monoxdifly said:
$$tan^2x\geq3$$
$$tanx\geq\sqrt3$$
Also consider that when you take a square root, there is usually a positive and a negative solution.
It should be:
$$\tan^2x\ge 3 \\
|\tan x|\ge \sqrt 3 \\
\tan x \ge \sqrt 3 \quad\lor\quad \tan x \le -\sqrt 3 \\
60° \le x < 90° \quad\lor\quad 90°<x\le 120° \quad\lor\quad 240° \le x < 270° \quad\lor\quad 270°<x\le 300°
Since we accidentally lost the solutions where $\cos x=0$, we can deduce that it is actually:
$$60° \le x \le 120° \quad\lor\quad 240° \le x \le 300° $$
It should be:
$$\tan^2x\ge 3 \\
That means I'm not completely wrong, am I?
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
