MHB Assistance needed for this ODE problem
  • Thread starter Thread starter heaviside
    Assistance Ode
heaviside
Hi,The problem I am trying to solve is in a section on first order ODEs. It is problem 25 in section 2.1 of Boyce & DiPrima's Elementary Diff Eq (5th Ed). The problem serves as an introduction to the variation of parameters, but again, it is in the first section of the book that introduces first order ODEs.
Find A(x) from (i). Then substitute for A(x) in (ii). Verify that the solution verifies with (iii).
(i)
[math]
A'(x) = g(x) \exp \lbrack \int p(x)\,dx \rbrack
[/math]
(ii)
[math]
y = A(x) \exp \lbrack -\int p(x)\,dx \rbrack
[/math]
(iii)
[math]
y = \frac{\int \mu(x)g(x)dx + c}{\mu(x)}
[/math]
This is what I have so far:
Integrate (by parts) equation (i):
[math]
\int udv = uv-\int vdu
[/math]
Let
[math] u = \exp \lbrack \int p(x)\,dx \rbrack [/math]
[math] du = p(x) \exp \lbrack \int p(x)\,dx \rbrack [/math]
[math] v = g(x) [/math]
[math] dv=g'(x) [/math]
This yields:
[math]
A(x)=g(x) \exp \lbrack \int p(x)\,dx \rbrack - \int g(x)p(x) \exp \lbrack \int p(x)\,dx \rbrack dx
[/math]
Putting this into equation (ii), yields:
[math]
y = \lgroup g(x) \exp \lbrack \int p(x)\,dx \rbrack - \int g(x)p(x) \exp \lbrack \int p(x)\,dx \rbrack dx \rgroup \bullet \exp \lbrack - \int p(x)\,dx \rbrack
[/math]
and thus (iv)
[math]
y = g(x) - \lgroup \int g(x)p(x) \exp \lbrack \int p(x)\,dx \rbrack dx \rgroup \bullet \exp \lbrack - \int p(x)\,dx \rbrack
[/math]
Now, I perform integration by parts again on the term in round brackets above:
Let
[math] u = g(x) [/math]
[math] du = g'(x)[/math]
[math] v = \exp \lbrack \int p(x)\,dx \rbrack [/math]
[math] dv = p(x) \exp \lbrack \int p(x)\,dx \rbrack [/math]
This yields:
[math]
g(x)\exp \lbrack \int p(x)\,dx \rbrack - \int g'(x) \exp \lbrack \int p(x)\,dx \rbrack dx
[/math]
Now (iv) becomes
[math]
y = g(x) - \lgroup g(x)\exp \lbrack \int p(x)\,dx \rbrack - \int g'(x) \exp \lbrack \int p(x)\,dx \rbrack dx \rgroup \exp \lbrack - \int p(x)\,dx \rbrack
[/math]
Simplifying:
[math]
y = \frac{\int g'(x)\exp \lbrack \int p(x)\,dx \rbrack dx}{\exp \lbrack \int p(x)\,dx \rbrack}
[/math]
Now the book defines
[math]
\mu(x) = \exp \lbrack \int p(x)\,dx \rbrack
[/math]
Therefore, what I have is:
[math]
y=\frac{\int \mu(x)g'(x)dx + c}{\mu(x)}
[/math]
Compare this to (iii) - you will see I have [math]g'(x)[/math] instead of [math]g(x)[/math].
So my question is: where did I go wrong. I've been looking over this for hours.
Thanks,
heaviside
Re: Assistance needed for this ODE problame
(i)
[math]
[/math]
(ii)
[math]
[/math]
(iii)
[math]
[/math]
[math]
[/math]
Let
I'm assuming you meant $dv = g'(x) \, dx$. Remember the Golden Rule of Differentials: if you have a differential on one side of an equation, you must have a differential on the other side as well.
This is not what you have in your integral. For by-parts, the integral you start with has to be the $\displaystyle \int u \, dv$. So you're saying, by setting up the by-parts this way, that your original integral is $\displaystyle \int g'(x) e^{ \int p(x) \, dx} \, dx$. But it isn't. Your original integral is $\displaystyle \int g(x) e^{ \int p(x) \, dx} \, dx$.
Try propagating this correction through your derivations, and see if it comes out right.
This yields:
[math]
[/math]
[math]
[/math]
and thus (iv)
[math]
[/math]
Let
This yields:
[math]
[/math]
Now (iv) becomes
[math]
[/math]
Simplifying:
[math]
[/math]
[math]
[/math]
[math]
[/math]
Thanks,
heaviside
That's it!
I just went through it again, with the change you suggested, and with more care. And the solution came out.
Thank you Ackbach!
heaviside said:
That's it!
Thank you Ackbach!
You're very welcome! Have a good one.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
