Astronomy Problems: Please Look/help
  • Thread starter Thread starter astronomystudent
    Astronomy
Help is being sought to solve various astronomy-related problems, including applying Wien's Law to determine Jupiter's energy emission wavelength, calculating the mass of a newly discovered planet, and finding the orbital period of Phobos around Mars. The discussions emphasize the importance of using consistent units in calculations, particularly when dealing with density and volume. Participants are encouraged to start problems independently to identify where they may be going wrong, and several equations relevant to the problems are shared, including Kepler's laws and the inverse square law for brightness. Clarifications on unit conversions and the relationships between different quantities are also discussed to aid understanding. Overall, the thread focuses on collaborative problem-solving in astronomy.
astronomystudent
I need help identifying equations and trying to start these problems. Thanks...
1.) If Jupiter has an average temperature of 125 K, at what wavelength is it emitting the most energy according to Wien's Law?
2.) If a new planet is discovered beyond the orbit of Neptune which has a radius three times Earth's radius and a densiy of 1.2 g/cc, what is the mass of the new planet in terms of Earth's mass?
3.) If Phobos had a semimajor axis of 29,000 km and Mars has a mass of 0.16 M(lowered E), what would be its period around Mars in hours? Be careful with your units here!
4.) If Jupiter were really 7.52 AU from the Sun instead of 5.20 AU, what would the affect be on the energy it gets from the Sun? What would be the affect on its appearence (size and brightness) from Earth? Careful, these are two different questions!
5.) If the size of a new Kuiper object is 0.0150 arc sec in angular size as seen from a distance of 42.00 AU, what is the true diameter? If it has a satellite with a period of 5.50 hours at a semimajor axis of 12500.0 km, what is the mass? What is the resulting density? What do you think it is composed of?
Astronomy news on Phys.org
Wein's law is an equation. Look it up in your book's index, and solve it.
Do you know how to find the volume of a sphere of radius r?
I'll continue with further problems once you start making an attempt. We're not going to do your homework for you.
- Warren
Answers To Numbers 1 & 2
I tried to do the first two problems. I looked up the formulas and stuff. I am still going to need help with the others. I just don't know where to begin.
1.) Wien's Law = (wavelength)(Temperature)= 2.898x10^7(constant)
(wavelength)(125 K) = 2.898X10^7
wavelength= 2.898x10^7/125 K
wavelength= 231,840 Angstroms
ANSWER = 231,840 Angstroms
2.) V=4/3(pi)r^3
density= mass/volume
New planet radius = 19134.45 km
V = 4/3(pi)(19134.45)^3
V= 2.93 X10^13 g/cc
density = mass/volume
1.2g/cc = mass/2.93 x10^13
(1.2g/cc)(2.93 x10^13) = mass
mass = 3.58 X10^13 kg
ANSWER = 3.58 x10^13 kg
Please let me know about these answers, and any other help you can offer on the other problems.
Right
2.) V=4/3(pi)r^3
V= 2.93 X10^13 g/cc
With the units you put in, this is the volume in km^3. g/cc is a unit of density.
This answer is way too small because your units are inconsistent between density and volume. Remember, g/cc means grams per centimeter cubed.
You got #1 right. But keep in mind that K does not mean constant. It means Kelvins. It's there to make the units dimentionally consistant.
Also, is Angstroms the best unit to express the answer?
#2. Wrong.
Becareful with your units. To get volume, you cubed kilometers, so you should end up with km^3, not g/cc.
Always do your math with your units, and never plug in your numbers until you have your formulas written to solve for the unknown. Then if your units cancel properly, you can be more confident with your answer.
Edit
** ST beat me to it :) . He and several others were quite helpful last year when I had similar questions.**
So is the answer to number 2 wrong or do I just have it labeled with the wrong units? Also, can I get some help on the other problems by chance?
The answer is wrong.
People here will be happy to help you with the others provided that you at least start the problem so we can see where you went wrong.
#3, do you have a formula for period?
And just a clue, you can Google for the answer to check yourself.
As tony said, you didn't get the right answer. I was just saying that you would get the right answer if you used a set of consistent units -- your equations are correct.
Forget about my hint to Google for the correct answer to check yourself. The problem says [if]. They changed both Mars' mass and Phobos' Semi-major axis.
For problem #2 I am still confused as to what I need to do. How do I keep consistent units, do I need to convert to different units.
For example, if you want the mass in kilograms, you have:
Mass (in kg) = Density (in kg per Liter) x Volume (in Liters)
Notice how the units cancel one another on the right side of the equation: kg -> kg/L*L. You can do this other ways:
Mass (in Earth masses) = Density (in Earth masses per centimeters cubed) x Volume (in centimeters cubed)
If the units you're given in the problem don't work out like in the above equations, then you need to convert them before plugging them into the equations.
2.) I understand what you are saying. I will try again after I convert my units and post my new work.
3.) I am trying to find the period in "hours". I found one equation for period and it reads as follows: P(years)=R(A.U.)^3/2
I have the semimajor axis which I think I plug in for P. Years is a gravitational constant, but then I have the mass and I don't know what to do with that. Is there another formula/equation for the period?
4.) I assume I use the equation for energy, but the energy equations don't include A.U. So I am lost? Also once you solve energy how do you begin to fid the "size and brightness" from Earth? Would that include telescope calculations?
5.) No idea, this problem is very difficult.
#3. The way you wrote it is basically Kepler's 3rd law. P is period, not semi-major axis. R is semi-major axis in A.U. (1 AU = Earth Sun average distance).
Look on Wikipedia for "Orbital Period". They've re-written that equation you give for more general use, with standard SI units.
#4. This one is easier than you think. You don't need energy equations, just the inverse square law. Basically, it says that if planet 2 is three times as far from the sun as planet 1, then it will receive 1/3^2 the amount of energy as planet 1.
#5. For part 1, look up small angle approximations. Part 2 is similar to #2 and #3 combined.
Okay, I think maybe I have the correct answer to number 2.
I converted the radius to cc.
So the new radius = 1.931445 x 10^13 cc
Thus the new volume = 2.93 x 10^40 cc
And the new mass = 3.52 x 10^40 g
ANSWER = 3.52 x10^40 g
Is that right?
For number four:
(apparent brightness (near)/apparent brightness (far)) = (distance (far)/distance (near))^2
so i...
(apparent brightness (near)/apparent brightness (far))= (7.52 AU/5.20 AU)2
answer = 2.09 x 10^9 (not sure of units)
I didn't understand your other notes about "the planet is 3x as far from the sun as planet 1, then it will receive 1/3^2 amount of energy as planet 1. Is what I did all I need to do? Am I missing another step and I am confused about which units go with my answer?
cc is a unit of volume. It stands for "centimeters cubed". I don't know how you got the above number, but you want the radius to be in centimeters.
The inverse square law will give you the relative amount of sunlight received at each planet. However, the brightness of a planet will depend not just on the amount of sunlight it receives and reflects, but also on how much of that light we get after the reflection. Can you see how these combined effects might scale with distance?
Okay, let's try number 2.
I converted the radius to cm: 1,913,445,00 cm
new volume = 2.93 x 10^28 cm
new mass = 3.52 x 10^28 g
How does that look?
I looked at your notes on number 4 and I am still confused. What exactly did I solve for, and how does that relate to what I need to do to solve the rest of the problem? Am I done or not? And in terms of distance, I am lost..
Thank you...
#2, no. This is where you made your error?
Do it with units:
V = 4/3(pi)(19134.45 km)^3
V = 4/3(pi)19134.45^3 km^3
V = 9491269039275.3 km^3
But since you're given density in cm^3 (also called cc), you don't want your volume to be in km^3. You want it to be in cm^3. What could you do to the original formula
to ensure that your answer comes out in cm^3?
How do you convert km to cm?
That looks good for number 2. But read the question again. They don't want you to express your answer in grams.
There are no units here. You're simply stating that the closer planet receives 2.09 x 10^9 times as much energy as the farther planet.
Does that answer seem reasonable? You did it right, but check your math.
Okay, I am not sure whether my answer for number 2 is write or wrong. You wrote that it was wrong, and then that is looked good? I need to convert my answer from grams to kg right b/c that is the units for mass right?
For problem 4 is that all I have to do for the problem? That is what I am asking. There are two parts to this question but I think i have only done one part?
You got it right. I said wrong before I noticed you posted your correct answer. 3.52 x 10^28 g is correct.
It's not asking for kg either. It wants you to express the new planet's mass in terms of Earth masses. You'll need to know the mass of the Earth to do this.
Part 4 gets trickier. It tells you how far the planets are from the Sun, but then asks you how that affects their brightness from Earth. Hint: It gives you their Sun distances in AU. How far is the Earth from the Sun in AU?
For number 2: the mass of the Earth is 5.97 x 10^24 kg.. so I do need to convert my answer to Kg but what dos "in terms of Earth's mass" do I divide
Also for number 3: I used the following equation and got an answer
T = 2(pi) (square root of a^3/u) where U = GM
T = 2(pi) (square root of (29,000^3)/(6.67x10^-11)(9.552x10^23)
T = 3.88746768x10^-11 hours
Answer = 3.9 x 10^-11 hours
I am still working on number 4 based on the information you gave me.
Okay, I think I understand what is meant in problem number 2
I divided the converted mass (kg) of the "new planet" by the mass of the Earth.
Therefore the answer is: 5.9 M(lowered E)? Is that what is meant?
Your answer for #2 is correct, 5.9Me.
You could have also converted the mass of the Earth into grams. That's easy. Just add 3 to your exponent.
5.97x10^24 kg =
5.97x10^27 g
#3, Does that seem like a reasonable answer? That means Phobos would go around Mars millions of times a second.
You're doing it right, but what are the units of G? And what are the units for Semi-major axis? Are they consistent? Also, watch out how you enter this into your calculator. It's a^3/(GM), not (a^3/G)*M which is how my calculator would want to do this problem if I entered it the way you typed it.
For problem number 3: I checked the units. If I convert the semi-major axis to meters than everything cancels out but seconds, because G's units are m^3/kg^-1/s^-2. The kilograms cancels out with the mass of the planet..
Thus after making the following changes: T = 122932.522 seconds. It wants the answer in hours so you convert T seconds ------> hours
T= 34.1479228
ANSWER = 34 Hours
Is that right?
For number 4: I am still lost. I have that one answer, but I am lost as what to do with the distances and how to apply your hint to the problem.
T= 34.1479228
ANSWER = 34 Hours
Is that right?
Yep.
This one's pretty tricky for an intro astronomy course. Try answering these two questions:
1) How is a planet's total reflected light related to its distance from the sun?
2) How is a planet's brightness related to its total reflected light and its distance from earth?
Still, problem 4. For Jupiter, the mean distance from the Sun is 5.2028 A.U., this is already given. The distance from the Earth to the Sun is 1 A.U. Does this have anything to do with the albedo? Is that a measurement of "brightness" or does that not have anything to do with it. Magnitude? Otherwise, I have no idea. Also, I am still unclear about what I have already solved for.
I did (7.52/5.20)^2 = 2.091360947 which is 2.0 X10^9.
  • #31
The brightness of a planet does depend on albedo, but does the albedo change when you change its distance from the sun?
2.09 is not equal to 2.0 x 109. The latter is exponential notation for two billion.
  • #32
So 2.09 is just 2.09 no exponents involved.
I think the albedo changes with temperature and it is dependent on the "surface." I don't think it changes with distance? But, I'm not sure. Am I on the right track? I Just don't know where I am going with this?
  • #33
If you let Jupiter settle into a new equilibrium at a larger distance from the sun, you might see a change in the albedo, but those effects will be negligible for this calculation. Only concern yourself with brightness and distance. Did you study "flux"?
  • #34
I am just lost on this problem. I don't even know what the 2.09 is in reference to. Are the units on that A.U.? Or do they cancel out or what?
  • #35
No, we have not studided "flux"
  • #36
When I look up brightness for Jupiter it comes up as -2.7 m. Is that something I could use. Could that be interpreted as the "apparent brightness near) and then I solve for the "apparent brightness far"? Or maybe that is all wrong, I don't know..
  • #37
It is the brightness I am trying to solve for right?
  • #38
Yes. I'm a little concerned about your approach to all this. What are you using for a text? Have you read it?
  • #39
Yes, I have read the text. We get problems that our teacher makes up b/c he thinks the ones in the text are really too easy. These problems are much more dififcult than the examples given in the book. We are also given a supplement packet that our teacher authored full of facts, and defintions. It has a whole section on planets: that is where I got the brightness for Jupiter to be -2.7m. Do I use that?
  • #40
No, you need to use the inverse square law. Do your notes or textbook cover this anywhere? What is the name of the text?
  • #41
Textbook: Astronomy Today
Chaisson - McMillan
  • #42
I used the inverse square law to find the answer for the other part of this problem.
I can find the ratio if I apply the 1.0 A.U. distance from the Earth ---- Sun
If I do the following: (7.52 A.U./1.0 A.U.)^2 = 56.5504
Could this then be how much brighter it would appear from Earth if it was at a farther distance? Or am I totally off? I really am trying, I feel like you think I'm not.
  • #43
Chaisson - McMillan
Read (or reread) section 10.4 and see if you can answer the question:
How does the sun's apparent brightness change if you double the Earth's distance from the sun?
  • #44
F.Y.I. we never really use our textbook we use a program called Voyager and do most of our lessons on there (it is a computer program). It comes with a book entitled: voyages through space and time - project for Voyager II by Jon K. Wooley. This teaches us a lot of stuff.
  • #45
My section 10.4 has nothing to do with that. That entire chapter is about Mars and section 10.4 is entitled: The surface of Mars. Nothing in that section refers to what you are talking about, it talks about canyons and other things. Maybe you have a different edition. I'm not really sure..
  • #46
No, I do think you're trying...the fourth problem is very difficult at this level. I think you should consider stepping back, though, cause you'll need a more complete understanding of what an inverse square law is before you can do this problem. Try starting with the question in my previous post.
  • #47
I just left you a note about that.
  • #48
Please try to treat this more like a message board, not a chat room. It's awkward to do this when you're posting new things every other minute. If you have several things to say, put them all in one post. Here is a link to an explanation of the 1/r^2 law that I wrote a while back:
https://www.physicsforums.com/showthread.php?t=70634"
Read it and see if you can answer the question in my last post.
  • #49
This isn't directly related to your problem, but if you know flux, #4 will be easier. Since your teacher didn't talk about it, I'll give you a quick review.
Flux is the amount of something (in this case, energy) that is transmitted or received by an area of surface. I like to think of it as departing and arriving flux, just like the airport terminals.
Imagine you have a light bulb that is spherical, and 10 cm in diameter. It is 100 W (Watts, also called Joules / S). How many Watts does each square centimeter of this light bulb emit?
What's the surface area of a sphere? 4 pi * r^2. You'll find the formula for surface area of a sphere poping up in lots of flux-related problems.
So the 10 cm diameter light bulb has a surface area of:
(Diameter is divided by 2 since the forumula wants radius.)
surface area = 4 * pi * r^2
surface area = 4 * pi * (10cm/2)^2 = 314.16 cm^2
Since the light bulb emits 100 W, each square cm emits 100W / 314.16 cm^2 = 0.318 W/cm^2. This is the departure flux from the lightbulb.
Now imagine the light bulb is in a spherical room 10 meters in diameter. How much energy does each square inch of this sphere receive from the light bulb?
What is the surface area of this sphere?
surface area = 4 * pi * ( (10m/2) * (100cm/m) )^2 = 3141592.7 cm^2
So each square centimeter of this room-sized sphere would receive 100W / 3141592.7 cm^2 = 3.18*10^-5 W/cm^2. This is the arriving flux.
When you want to compute something such as how much flux of sunlight does the Earth receive, you just treat the Earth as a point on the surface of a sphere whose radius is 1 AU.
Notice a similarity in the answers? The departing flux, from d=10 sphere is 0.318. The arriving flux from d=1000m is 3.18*10^-5 W/cm^3.
d2 is 100 times more than d1.
f2 is (1/100^2) that of flux 1. (inverse square law)
This is why you only need inverse square law to solve for #4. You'll need flux later, but knowing it now will help you wrap your mind around this problem a little better.
  • #50
Ok, I have looked at these sites/notes on the inverse square law. However, these seem just like a string of examples. I don't have anything that is in WATTS, nor do I have luminosity. I just have the distance. I am still confused as to what it is here that you are suggesting I do to solve this problem. Still the only part of the problem I have done is (7.52/5.20)^2= 2.09. And I don't even know what that means... maybe I am just dumb/oblivious. But I am REALLY confused...
