Asymmetric Tensor: Overview & Uses
  • Context: Undergrad
  • Thread starter Thread starter izzi wekwek
    Tensor
The discussion revolves around the concept of asymmetric tensors, including their properties and applications. Participants engage in clarifying the context of the inquiry, addressing formatting issues related to mathematical expressions, and exploring the implications of specific terms within the discussion.
  • Meta-discussion, Conceptual clarification
  • One participant questions whether the inquiry is a homework problem and suggests it should be posted in the appropriate forum with the correct template.
  • Another participant clarifies that their inquiry is self-directed learning, not homework.
  • A suggestion is made regarding the proper use of LaTeX for formatting equations to facilitate quoting and responses.
  • Concerns are raised about the lack of clarity regarding the term "omega," noting its antisymmetry and the simplification of summation leading to a specific number of independent components.
  • A participant expresses confusion about the original question, asking for clarification on what the inquirer aims to achieve with their calculations.
Participants do not reach a consensus on the original question's intent, and there is a lack of clarity regarding the specific calculations being discussed. Multiple viewpoints on the inquiry's context and formatting persist.
Limitations include the absence of definitions for specific terms like "omega," which affects the understanding of the discussion. The inquiry's goals remain unspecified, leading to varied interpretations among participants.
izzi wekwek
Is this a homework problem? If so, it should go in the appropriate homework forum, and the homework template should be filled out.
Also, formulas should not be pasted in as images; they should be done using the PF LaTeX feature. Otherwise it's impossible for people to quote your formulas properly when responding.
No, this is not a homework, I just learn by myself. thank you for your suggestion.
If you generated your equations using LaTeX, simply enclose the code for each equation between $$ delimiters on each side (for standalone equations) or ## delimiters (for "inline" equations, embedded inside a paragraph).
We also don't know how to calculate the term, because you don't give us what this omega is. Because omega is antisymmetric, the summation however simplifies, because only ##\frac{1}{2}D(D-1)## components of it are independent.
To answer the original question, you have to tell us what you want to achieve. I don't understand what you mean by "how to calculate it". It's just the expression you wrote down, what else should it be?
  • · Replies 19 ·
  • · Replies 22 ·
