At what velocity should relativity be taken into account
Relativity should be considered when velocities approach a significant fraction of the speed of light (c), which is approximately 300,000,000 m/s. The discussed velocity of 6.5 x 10^6 m/s is about 2% of c, resulting in a minimal error of around 0.03% if relativistic effects are ignored. For most practical calculations, especially with limited precision, this velocity can be treated as non-relativistic. However, if higher precision is required or if velocities increase significantly, incorporating relativity becomes essential. Understanding the context and precision needed for calculations is crucial when determining the relevance of relativity.
moonkey
I have exams coming up and I'm just looking for an idea of when relativity should be taken into account. For example I'm just going over a question involving photoelectric effect and potential fields and de Broglie and all that jazz and the final velocity of the electron turns out to be around 6.5x106ms-1. Should I take relativity into account for this velocity or is it still safely within the margins of non-relativistic velocity? I'm thinking that it is safe to assume that it is non-relativistic but I would like some advice just in case such a question arises that involves a greater velocity.
OOPS. Forget I said anything (it turned out to be not relevant, so I deleted my comment)
At a first glance, I'd say it depends on the precision that you want.
Since c is 300.000.000 m/s your speed is a 2% of c, which gives you an error of 0.03% if you ignore c (if I am not wrong).
If you use just only 3 figures (e.g. 0.134) in your data, then ignore it.
That makes perfectly good sense.
Thanks Quinzio
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
