Athlete jumps at angle with distance find speed
  • Thread starter Thread starter afa
    Angle Speed
To find the take-off speed of an athlete jumping at a 33.6-degree angle and traveling 7.77 meters, the equation Vx = Vcos(theta) is used, but accurate time calculations are crucial for a correct solution. The discussion highlights the importance of understanding horizontal versus vertical displacement, as well as the need for time to solve for two variables. For a second scenario with a 30-degree angle and 8.90 meters traveled, participants emphasize the necessity of using the range equation due to the lack of vertical displacement. The conversation also suggests starting new threads for different problems to receive better responses. Ultimately, the calculations hinge on correctly applying the equations of motion and understanding the relationships between velocity, time, and displacement.
afa
Leaves the ground at a 33.6 degree angle and travels at 7.77 m. What is take off speed?
If speed were increased by 4% how much longer would the jump be?
Vx=Vcos(theta)
7.77=vcos33.6 got 9.33 but says it wrong, then I added 4% to this and did 9.7cos33.6 which also seems to be wrong..what am I missing?
Time my friend-time. What`s the time what it takes to travel.
Hi afa, could you be a little more specific please, you say he travels 7.77m, but where? Horizontally / Vertically / Diagonally? Is this all of the question or is there more detail to it?
Jared
I'm having a similar problem:
An athlete executing a long jump leaves the ground at an angle of 30 degrees and travels 8.90m. What was the take-off speed?
Both responses from juggernaut and myself above apply to this second problem as well.
Jared
travels horizontally 8.90m, no vertical displacement, time is unknown, how do I solve for two variables? Or what do I substitute velocity or time with to solve for the other?
Leaves the ground at 30 degrees, but there's no vertical displacement?
You really do need the time factor, and based on what you have given you can't calculate it as far as I can tell.
I'm not sure if you can solve with only two variables. Try rearranging your equations of motion to get something you can solve (perhaps simultaneously).
You can't just substitute time or velocity as they'll generate different answers.
dmkeddy, you should start your own threads for things like this and not hijack an old one as it will gain you a better response.
Since you have to assume that his y displacement is zero by the time he lands, you could use the range equation for this which is (v^2)sin(2x)/g. You know the range is 7.77 and you know x, which is the angle. So solve for v. For the second case, all is being kept constant, except for velocity. So the equation should be kept normal but except for where you write v^2 write (1.04v)^2. If you simplify, you'll note that everything is the same except for the 1.04^2. Hence, just multiply 7.77 by 1.04^2.
