Are Electrons & Protons Oriented in Stars Like Other Objects?
In summary, the sun is composed mainly of hydrogen atoms undergoing fusion, but it does not create iron. The orientation of electrons and protons within the sun is not predictable, as it is a ball of plasma. Stars can die in different ways depending on their mass, with smaller stars becoming white dwarves and larger stars possibly resulting in supernovae. The photosphere of the sun does contain some neutral atoms, but the majority of its composition is plasma. The creation of elements in stars depends on their mass, with heavier elements being produced in more massive stars. Our sun is not predicted to go through the process of creating iron or exploding as a supernova.
PhDnotForMe
56
So the sun is largely hydrogen atoms and those hydrogen atoms are undergoing fusion all the way up until they reach iron. My question is are the electrons orbiting around the nucleus just as they are in any normal object? Or is the sun just like a pool of electrons and protons floating around with no predictable order in regards to the relation between electrons and protons?
Basically what is the orientation of electrons and protons within objects as hot and dense as stars.
Astronomy news on Phys.org
The Sun is a big ball of plasma. There are no atoms in it, in the sense of electrons connected with a particular nucleus.
By the way, the Sun will never end up producing iron. It is not big enough for that.
Likes Keith_McClary, davenn, stefan r and 1 other person
Interesting! Thanks. I just looked into what you said about iron. It checks out! Interestingly enough there is in fact Iron within the sun but apparently that is from previous stars. The sun doesn't create it and I guess it never will? I was under the impression that super novas were caused by stars only creating iron and getting no return on energy and thus creating a cooling effect that expands the star into an explosion. I know our star is predicted to die at some point. Can you help me connect some dots? I feel like I'm missing something. Can stars explode before reaching the creation of iron stage?
Going supernova is not the only way for a star to die. Smaller stars essentially die by no longer being able to sustain fusion and gradually fade away to become white dwarves.
Likes PhDnotForMe
The photosphere of the sun does have hydrogen and other atoms which give rise to the absorption lines in the solar spectrum.
Regards Andrew
Likes Keith_McClary and PhDnotForMe
How star evolve depends on their mass. Large massive stars can end as supernovae. Stars like our Sun expand into red giants, Then later will blow off some of its mass before shrinking to a white dwarf. Stars much less massive than or Sun like Red dwarfs, will burn pretty much steadily for trillions of years before finally exhausting their fuel and settling into a white dwarf stage.
Likes PhDnotForMe
Wikipedia's article on stellar evolution is good IMO. If you want something better you should probably get an astronomy textbook and just dig in. Also see articles on main sequence, evolution of the solar system, the Sun, red giant branch, and asymptotic branch, and white dwarf.
  • Love
FYI: A.G.W. Cameron's updated and revised text: "Stellar Evolution, Nuclear Astrophysics, and Nucleogenesis" is still available on Amazon.
Likes PhDnotForMe
Regards Andrew
It is mainly neutral atoms, in fact. Just 0.04% of the hydrogen atoms are ionized at an optical depth of 1. For helium that fraction should be much smaller.
Bilderberg model
Likes stefan r and andrew s 1905
I'm not an expert / scientist but as I understand it the elements created go up the periodic table. From hydrogen, to helium and the rest depends on the mass of the star. If the star has sufficient mass, i.e. is has sufficient pressure in it's core, it can go on to produce heavier and heavier elements until the pressures it can produce can no longer sustain fusion at that stage and begin to die and become a red giant.
Only the biggest stars have sufficients mass / pressure in their core to go on producing heavier and heavier elements until they start producing iron and then go supernova at that point. The vast majority of stars are not big enough to get to this phase though. Our sun is not big enough and will never produce any iron.
1. Are electrons and protons oriented in stars in the same way as other objects?
Yes, electrons and protons in stars are oriented in a similar manner as other objects in the universe. They follow the same laws of physics and interact with each other through electromagnetic forces.
2. How are electrons and protons arranged in stars?
Electrons and protons are arranged in stars according to their energy levels. The electrons occupy different energy levels around the nucleus, while the protons are found in the nucleus. This arrangement is known as the electron cloud model.
3. Do electrons and protons have different orientations in stars?
Yes, electrons and protons have different orientations in stars. Electrons have a negative charge and orbit around the nucleus, while protons have a positive charge and are located in the nucleus. This results in different orientations for the two particles.
4. Can the orientation of electrons and protons in stars change?
Yes, the orientation of electrons and protons in stars can change. This can happen due to various factors such as changes in temperature, pressure, or interactions with other particles. However, the overall arrangement and orientation of these particles remain relatively stable in stars.
5. How do the orientation of electrons and protons affect the properties of stars?
The orientation of electrons and protons in stars plays a crucial role in determining the properties of stars. For example, the number of protons in a star's nucleus determines its atomic number and chemical properties. The arrangement of electrons also affects the energy levels and spectral lines observed in stars, providing valuable information about their composition and temperature.
  • Astronomy and Astrophysics
  • Quantum Physics
113K
