Atwood's machine with 3 masses
  • Thread starter Thread starter AHinkle
    Machine
The discussion focuses on solving the tension in an Atwood's machine setup with three masses: 2kg, 3kg, and 6kg. The participants derived equations based on Newton's second law, leading to the calculation of tensions T1 and T2. The final correct tension between the 2kg and 3kg masses (T1) was determined to be 21.3818 N after correcting an oversight regarding gravitational forces acting on all masses. The solution emphasizes the importance of including all forces in the analysis for accurate results.
  • Understanding of Newton's second law (F=ma)
  • Knowledge of free body diagrams
  • Familiarity with Atwood's machine concepts
  • Basic algebra for solving equations
  • Study the derivation of tension in multi-mass pulley systems
  • Learn about free body diagram techniques for complex systems
  • Explore advanced applications of Newton's laws in dynamics
  • Investigate the effects of friction and mass on pulley systems
Students in physics, educators teaching mechanics, and anyone interested in understanding dynamics in pulley systems.
AHinkle
A pulley is massless and frictionless, 2kg, 3kg, and 6kg masses are suspended. The 2 and 3 kilogram masses are suspended on the left side of the pulley (the 2 kilogram mass on the bottom) and are connected by a cord of negligible mass that does not stretch(T1), the 6kg mass is suspended on the right side and is connected around the pulley via a cord of negligible mass that does not stretch (T2). Down is the positive direction on the right side, up is positive on the left. what is the tension on the string between mass 1 and mass 2.
Fnet=ma
Sorry there's not a picture. I did not have anywhere to host it.
I drew free body diagrams for each mass and came up with the Fnet equations for each. I assume we're only working with y accelerations.
m3g-T2=m3a
T2-T1=m2a
T1-m1g=m1a
I added the equations together for m2 and m3 because they're connected by a cord and
the acceleration for the whole system should be the same.
m3g-T2+T2-T1=(m2+m3)a
m3g-T1=(m2+m3)a
m3=6kg m2=3kg g=9.8
(6kg)(9.8m/s^2)-T1 = 9a
i solved for a
T1-m1g=m1a
a = (T1-m1g)/(m1)
58.8-T1=9((T1-m1g)/(m1))
58.8-T1=9((T1-(2)(9.8))/(2))
58.8-T1=(9T1-176.4)/(2)
117.6-2(T1)=9(T1)-176.4
294-2(T1)=9(T1)
11(T1) = 294
T1 = 26.7272 N
I felt like i did this right, and it's tormenting me..
In your second equation T2 -T1 = m2a, you forgot to include the weight, m2g, in that equation.
AHinkle said:
T2-T1=m2a
This equation i wrong. Gravity acts on all masses!
ehild
Thanks guys, I got it right. That small oversight cost me an hour at least.
m3g-T2 = m3a
T2-T1-m2g=m2a
T1-m1g=m1a
m3g-T1-m2g=(m2+m3)a
a=(T1-m1g)/(m1)
(6)(9.8)-T1-(3)(9.8)=9a
58.8-T1-29.4=9a
29.4-T1=9a
sub in a
29.4-T1=9((T1-m1g)/(m1))
29.4-T1=((9)(T1)-(18)g)/2
58.8-2(T1)=9(T1)-176.4
-(2)(T1)=(9)(T1)-235.2
-(11)(T1)=-235.2
T1= (-235.2)/(-11)
T1= 21.3818 N
It is an easier job if you add up all equations. That cancels all inner forces (tensions here) and you get the acceleration as the total external force divided by the total mass. Knowing the acceleration, it is easy to find the tensions.
ehild
  • · Replies 97 ·
16K
  • · Replies 30 ·
