Auto-covariance of a Wiener process of a function
  • Thread starter Thread starter fortissimo
    Function Process
fortissimo
Let {W(t); t >= 0} be a Wiener process. Determine the auto-covariance function for the process {X(t); t >= 0} defined by X(t) = e^(-ct) * W(e^(2ct)) for all t >= 0, where c > 0 is a constant.
Is {X(t); t >= 0} stationary in the wide sense?
Is this possibly in the right direction?
C_X (t,τ) = Cov(X(t), X(t+τ)) = Cov(e^(-ct) * W(e^(2ct)),e^(-c(t+τ)) * W(e^(2c(t+τ)))) = e^(-c(2t+τ))*Cov(W(e^(2ct)), W(e^(2c(t+τ)))) = α*e^(-c(2t+τ))*min{e^(2ct),e^(2c(t+τ))}.
The process is not stationary in the weak sense since the auto-correlation function (equal to the auto-covariance here?) varies with t.
I have solved the problem, no need to reply to this.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
