Average Acceleration (gravity question)
The discussion centers on calculating the time it takes for an object to fall to Earth from a height of 2500 km, considering the variation in gravitational acceleration with distance. The initial formula used, t = √(2D/g), applies well for short distances but becomes inaccurate at larger heights due to the decrease in g. Participants suggest that while using an average gravitational acceleration (g_avg) might simplify calculations, it would likely underestimate the total falling time. For more accurate results, especially over significant distances, solving an integral is recommended. The conversation emphasizes the complexity of varying acceleration in gravitational problems.
clm222
Hello. I was doing some physics and I came across a problem involving gravity.
The problem was finding out how long (in disregaurd to atmosphere) long (time) it would take for a body to reach earth. I'm familiar with distance's derivatives, which give me:
t=\sqrt{\frac{2D}{g}}
where t=time D=distance g=gravitational acceleration.
Although using g=9.8 is fine for short distances, it wouldn't really work at, say 2500km (about g=5) above the surface of the earth.
I'm curious as to how I may find the time it will take the object to fall? I'm not worried about what happens in between the distance. I'm not taking into account other bodies in the universe (its just a hypothetical physics problem). Since the derivative of g will depend on distance, and since D(t) is dependant on g, that doesn't really work. I'm wondering if i can use the average value of g? although the first bit of time will calculate the body being faster, the last bit of time it won't be getting as much speed. Can I do this?
does:
t=\sqrt{\frac{2D}{g_{avg}}}?
can I do this for any varying acceleration? I know how to find averages of functions, please help.
The same question was discussed here yesterday. In the general case, you have to solve an integral.
If the falling distance is not too large (still small compared to the diameter of earth), you might get away with an average g, but this will underestimate the falling time.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
