What is the value of the square root of the mean of the square current?
The discussion focuses on calculating the average of the square of the current drawn by a television set with an rms current of 2.25 A. Participants clarify that the task is to find the average of the square, not the square of the average, which is misleadingly zero. The root mean square (rms) concept is emphasized, indicating that the average of the square of the current can be derived from squaring the rms value. The conversation also touches on the properties of a standard sine wave and its squared values, leading to a mean of 0.5. Ultimately, the correct approach involves understanding the relationship between rms and the average of the square.
phy112
A television set draws an rms current of 2.25 A from a 60 Hz power line.
What is the average of the square of the current?
Irms=square root of average of isquared
i found the average of the current to be 0. I just keep getting 2.53, which is the wrong answer!
You're not being asked to find the square of the average which is zero, you're supposed to find the average of the square.
Hint: What's another word for average?
do you do 2.25squared?
Think about rms (root mean squared) and how the rms value is calculated. Compare that to the question.
rms=1/squarerootof2*amplitude? i get 2.24
Root Mean Square means we're taking the square root of the mean of the square. For a standard sine wave with maxima and minima at +1 and -1 and a mean of 0, when it is squared the maxima and minima become +1 and 0 and the mean is 0.5. The square root of the mean is 0.707.
You are given the square root of the mean (average) of the square. If you square that value, what do you have?
