Back EMF Paradox: Is There a Contradiction?
The discussion centers on the concept of back electromotive force (emf) in RL circuits, particularly at time t=0 when the current is initially zero. Participants clarify that back emf arises from a changing magnetic field rather than a static one, emphasizing that a significant change in current leads to a large back emf. Faraday's law is cited as the principle governing the existence of back emf, which is dependent on the rate of change of current rather than its absolute value. The example of superconductors is debated, with the assertion that they can still exhibit inductive behavior without generating back emf when the current is constant. Ultimately, the conversation resolves around the understanding that back emf is linked to changes in current and magnetic fields, not their static presence.
Conservation
Correct me if I am wrong.
For a RL circuit, I know as a fact at t=0, there is a back emf that is almost equivalent to the original emf source. In order for the back emf to exist, there needs to be a magnetic field in the inductor. In order for there to be a magnetic field in the inductor, there needs to be a current flowing through the inductor. In fact, the current would need to be close to the maximum current to induce such a large back emf noticeable at t=0. Yet, at t=0, I also know that the current in an RL circuit is 0. And so on.
Is this a paradox? What did I miss here?
This is incorrect. A magnetic field in an inductor does not produce any EMF. A good example is a superconducting MRI magnet where very large magnetic fields exist with no back EMF whatsoever.
A back EMF opposes a change in the magnetic field, not a static magnetic field. To get a large back EMF you need a large change in the field, which is, in fact, what you get in a RL circuit at t=0.
Hm...
The way that I learned back emf is that it is the induced emf from the changing magnetic field in the inductor. (Sorry, didn't say changing in OP) It makes sense that there would be a maximum back emf at the point of maximum rate of change of current, t=0; but to your definition, what accounts for the physical existence of a back emf? Without a current in the inductor, I don't see how there can be back emf.
Also, isn't a superconductor a bad example (Meissner effect)?
Then it sounds like you learned it correctly, but simply are not applying it correctly. The basic equation for an inductor is ##v=L \; di/dt##. The actual value of i is not relevant, only the time rate of change of i.
Faraday's law accounts for the back emf.
In an inductor, including a superconducting inductor, the magnetic field goes around the wire, not through it. So the Meissner effect doesn't prevent a superconducting coil from acting like a big inductor. The point is that Faradays law, applied to a superconductor, allows a large field/current to exist without any EMF. It is only when you are changing the current that you get an EMF.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
