Is Algae and Bacteria the Perfect Combination for Biodiesel Production?
In summary: The original methods of releasing the oils involved presses and or chemicals. There are people using other technologies, such as ultrasound, and pressure based extraction methods.
Ivan Seeking
Staff Emeritus
1,756
A number of strains of microalgae are known to produce relatively high yields of energy as fuel stock [pre-biodiesel] in the form of plant oils, as a function of area and time - typically as BTU/acre-year, or MJ/hectare-day, etc.
From a review of the literature, it is my perception that microalgae have the highest solar conversion efficiency [in producing sugars and oil] of any plant option due to not only the simplicity of the organism, but also because its small size and geometry allows for approximately 100% utilization of the available sunlight. So, for starters, is my information correct?
Next, one of the biggest challenges in making biodiesel from algae is the extraction of the oils. That, combined with the fact that algae consists of sugars, oil, and fiber, suggests to me that bacterial processing of algae could be an ideal approach to fuel production.
How does it work? A special type of genetically altered bacteria are fed plant material: basically, any type of sugar. They digest it and excrete the equivalent of diesel fuel.
Humans have used bacteria and yeast for centuries to do similar work, creating beer, moonshine and, more recently, ethanol. But scientists' recent strides in genetic engineering now allow them to control the end product. Watch the fuel-making process at work »...
http://www.cnn.com/2008/TECH/science/08/12/bug.diesel/index.html
It seems to me that while producing fuel from the available sugars, the bacteria would consequentially release the oil stored in pockets, in the algae. So we get not only the oils already stored in the algae, but also the oils converted from sugars by the bacteria. This would seem to solve many problems with algae processing while increasing the yields. Also, if algae has the highest conversion efficiency [sunlight to hydrocarbons] of any plant - as a function of area and time - then it would seem to be the ideal choice for fuel production using engineered bacteria.
Thoughts?
Biology news on Phys.org
Algae don't utilize anywhere near 100% of the available sunlight. More like 10% of the sunlight in the absorption range for that particular algae*.
It isn't. Conventional extraction methods from chemical engineering work just fine**.
I'm not sure how you think bacteria could do the job. Do you happen to know of any bacteria that do that?
Anyway, the use of bacteria to perform an anaerobic digestion of the remaining biomass in order to produce biogas (and perhaps other useful products), which could provide the energy for the production and extraction processes, is already being proposed.
*Bolton, J.R. (1996) “Solar photoproduction of hydrogen.” Report to the Int. Energy Agency, IEA/H2/TR-96.
** Belarbi, et al, "A process for high yield and scaleable recovery of high purity eicosapentaenoic acid esters from microalgae and fish oil", Enzyme and Microbial Technology 26 (2000) 516 –529
That is the conversion efficiency - actually I think that is the typical par [photosynthetically active radiation]. But I am talking about geometry in addition to the efficiency in converting water and CO2 into sugars and other hydrocarbons.
They are energy intensive [and/or expensive].
See the link.
That is also true. The bacteria linked in the report would convert this biomass directly into fuel, which is the point of the thread. In the process, it seems to me that pockets containing the oil would be degraded and release the oil.
The point is that it might maximize the oil production rate and efficiency by combining the two technologies.
Centrifuges have always been a weak link in the algae process. They are energy intensive and problematic. If the oils could be released while the algae is in suspension, perhaps as a 10% solution, after a settling pool, the centifuges might be avoided altogether.
The original methods of releasing the oils involved presses and or chemicals. There are people using other technologies, such as ultrasound, and pressure based extraction methods. and I have even heard of microwaves being used to explode the oil pockets [I think], but in all cases the process is an energy negative and an expense. By using bacteria to do this job, the process becomes a net energy and financial positive.
Part of the point here is that while algae will readily produce plant oil, there is always a compeitition between oil production, and sugar production. There is actually a biological switch that selects for one or the other. The bacterial process would make this issue moot as both the sugars and oil are ultimately used as fuel stock.
Centrifuges are not used for oil extraction AFAIK, but simply to remove as much water as possible.
Not that I see the problem here, given that centrifuges/cyclones are used all the time in ordinary chemical engineering.
Which doesn't make it expensive since the chemicals are not consumed in the process and can be reused. Liquid phase extraction is a quite common, cheap and mature tech.
These are technologies to break up the cellular membranes. I don't know of any bacteria that can do that. In fact, with most microbacterial techniques, you still end up needing to do that job.
Well that's a fine idea, provided you can find some bacteria that will both break up algae and turn the resulting sugars into oil, and then break up themselves.
A review of the industry reveals that centrifuges are highly problematic. This goes all the way back to the Aquatic Species Program that first studied algae for fuel production. Right now there is an engineer at OSU working to resolve some of these problems. He gives it five years before the issues are all resolved [which means it could take much longer]. Also, it is an energy negative. The efficiency of the processing has a direct bearing on the viability of algae as a fuel source.
Are you talking about supercritical extraction methods?
Are you kidding here? Have you read the link? That was what motivated the thread in the first place.
Either read the link or please quit responding.
alxm said:
Algae don't utilize anywhere near 100% of the available sunlight. More like 10% of the sunlight in the absorption range for that particular algae.
I think the best agriculture (vs. aquaculture) fuel conversion efficiency is about 2% (for miscanthus biofuel), so 10% is a big number. Food sugar (meaning saccharide- C6 H12 O6) production in grains (wheat, rice, etc) is in the realm of 0.1%, which is why the World needs about 4 billion acres of cultivated land to produce food for 6.7 billion people.
All we have done in the last 10,000 years since we began farming is interbreeding crops for better yield, tolerance for drought, and resistance to disease etc. Crops are still using the old Calvin (or C4) photosynthesis cycle. How about having bacteria create food sugars with 10% efficiency?
1. What is the process of producing biodiesel from bacteria and algae?
The process involves cultivating a specific type of bacteria and algae in a controlled environment, such as a bioreactor. These microorganisms are then harvested and processed to extract their oils. The oils are then converted into biodiesel through a chemical process called transesterification.
2. How is the quality of biodiesel produced from bacteria and algae compared to traditional biodiesel?
Biodiesel produced from bacteria and algae is considered to be of higher quality compared to traditional biodiesel. This is because the oils from these microorganisms have a higher purity and consistency, resulting in a more efficient and cleaner burning fuel.
3. What are the benefits of using bacteria and algae as sources of biodiesel?
There are several benefits to using bacteria and algae as sources of biodiesel. These include their high oil content, ability to grow and reproduce quickly, and their ability to thrive in diverse environments, making them a sustainable and renewable source of fuel.
4. Are there any challenges in producing biodiesel from bacteria and algae?
While bacteria and algae have potential as sources of biodiesel, there are some challenges in the production process. These include the need for specialized equipment and expertise, as well as the high cost of production compared to traditional biodiesel sources.
5. How does the production of biodiesel from bacteria and algae impact the environment?
Biodiesel produced from bacteria and algae has a positive impact on the environment. These microorganisms can be grown in non-arable land using wastewater or other waste products as nutrients, reducing the use of valuable resources. Additionally, biodiesel has a lower carbon footprint and produces fewer harmful emissions compared to traditional diesel fuel.
24K
  • Other Physics Topics
  • Biology and Medical
  • Earth Sciences
  • General Engineering
