I Balancing a teeter-totter problem
  • I
  • Thread starter Thread starter johnrot
The discussion revolves around the mechanics of a teeter-totter system affected by a fan's thrust. Two solutions are proposed regarding the direction of rotation when the fan is turned on: one suggests counterclockwise rotation due to internal forces, while the other argues for clockwise rotation based on external forces. A key point raised is that the universal joint cannot transfer moments, complicating the analysis of the system's behavior. The conversation also touches on the horizontal movement of the man's center of mass while leaning back to counteract the fan's thrust. The thread concludes with a note about the original post being restored after deletion, and a reminder about maintaining thread integrity.
johnrot
this is teeter,it can rotate at point B
in first picture fan is turn off and teeter is in balance,point A is universal joint..
https://www.physicsforums.com/attachments/261054
now fan is turn ON and men is lean back to hold fan thrust...
Question is, will be teeter start rotate in clockwise or in counter clockwise direction?
https://www.physicsforums.com/attachments/261061two solution:
1) universal joint can't transfer moment only horizontal and vertical forces,so that mean that "side force" act in level of men feet,projection of this force is below point B so teeter will rotate in counter clockwise direction..
here is problem that "side force" is internal force in system but internal force can't "rotate system"..
2)only external force can "rotate system" so thrust at fan act above point B so teeter will rotate in clockwise direction
here is problem that u.j. can't transfer moment ,so how would thrust rotate teeter...
I am with solution 1)
What is your answer?
johnrot said:
...men is lean back to hold fan thrust...
Does his center of mass move horizontally while he leans back?
Did you consider the horizontal force of the feet on the teeter?
OP deleted his post after receiving the reply by @A.T. so we have restored the Original Post and the thread will remain locked for now.
@johnrot -- please do not delete or edit your OP after you have received replies. Check your PMs and let me know if you want this thread re-opened.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
