Ball Acceleration and Trajectory Question
The discussion revolves around a physics problem involving a ball dropped from a height of 39.0m, affected by horizontal wind acceleration of 1.20 m/s². The trajectory of the ball is determined to be a straight line, with the angle θ calculated as 83° using the arctangent of the vertical and horizontal accelerations. To find the horizontal distance R, the relationship R = 39.0m/tan(83°) is suggested, linking it to the geometry of a right triangle. The time taken for the ball to reach the ground and its impact speed are also key aspects of the problem. The conversation emphasizes understanding motion in two dimensions and applying the Pythagorean theorem for calculations.
hueyosie
A ball is dropped from a height of 39.0m. The wind is blowing horizontally and imparts a constant acceleration of 1.20 m/s^2 to the ball.
a. Show that the path of the ball is a straight line and find the values of R and θ (R is the distance on the x-axis from the ball's starting point to the ending point and θ is the angle between the x-axis and the ball's landing point... sorry if that's not clear! It's in the book's diagram and I'm not sure how to get the image here)
b. How long does it take for the ball to reach the ground?
c. With what speed does the ball hit the ground?
I know that the x acceleration is 1.2 m/s^2 and the y acceleration is 9.8 m/s^2 (should gravity ever be a negative value?) but I'm not sure where to go from there. According to the solutions guide, θ=arctan(9.8/1.2)=83°, which I understand, but I'm not sure how to get the R value, (the solutions guide says R=39.0m/tan(83°) but I'm not sure what equation they used for it). Any help would be appreciated! I'm having trouble with questions with motion in two dimensions because I'm not sure how to approach the questions, so if anyone has any tips, I'd really appreciate that as well :)
Think of this question as a right triangle. If your bottom angle is 83°, assuming that you have found it already, then it is a simple matter of using the Pythagorean theorem to find R.
Thank you so much! I understand that part now.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
