Determining Viscosity of Oil Using a Dropped Ball Experiment
  • Thread starter Thread starter getty102
    Ball Oil viscous
The discussion revolves around determining the viscosity of oil using a dropped ball experiment, with the position of the ball described by the equation y=Y+At+Be-Ct. Key initial conditions include y=0.070 m at t=0, a velocity of 0, and an acceleration of 0.0983 m/s². As time approaches infinity, the velocity approaches 0.480 m/s, leading to a system of equations derived from the position and velocity equations. The participants emphasize the importance of correctly interpreting the behavior of the exponential term as t approaches infinity to solve for the unknown variable Y. The conversation concludes with a suggestion to use algebra to solve the resulting equations for Y.
getty102
In an experiment to determine the viscosity of some oil, a ball is dropped into some oil. The position of the ball is given by the formula y=Y+At+Be-Ct. At t=0, y=0.070 m, the velocity dy/dt is 0 and the acceleration is 0.0983 m/s2. As t→∞ the velocity approaches 0.480 m/s. What is the value of Y in MKS units?
y=Y+At+Be-Ct
vy(t)=A+-CBe-Ct
ay(t)=C2Be-Ct
With four unknowns (Y,A,B,C), I came up with three equations:
B+Y=0.070m
A=CB
BC2=0.0983
I wasn't sure what to do as t→∞
Looking at your velocity equation, what happens to the exponential term as t approaches infinity? What does the exponential function look like as its exponent approaches infinity? What if the exponential is in the denominator? Try using a graphing program or wolfram alpha to plot it.
as t→∞ the exponent would turn to negative, therefore it would go to 0. But that would give me
vy(∞)=A-CBe-C∞
0.480=A-CB(1)
if A=CB
0.480=CB-CB
and
0.480≠0
You said the exponential term would go to zero but you plugged a 1 into your equation. Yes e^{-t} goes to zero as t approaches \infty.
I skipped a step there, sorry. Yea I figured e^-Ct would go to 0 as t goes to infinity, but the math did not work out. Any more suggestions?
If the exponential term goes to 0 in your velocity equation, then you end up with 0.480=A correct? This gives you a 4th equation to solve for your 4 unknowns. Now you just have to do some algebra and solve the system of equations for Y.
