songoku
- 2,467
- 382
Two steel balls, each of diameter 24.9 mm, moving in opposite directions at 4 m/s, run into each other head-on and bounce apart.
a. Compute an estimate for the time interval for which the balls are in contact.
b One of the balls is squeezed in a vise while precise measurements are made of the resulting amount of compression. The results show that Hooke's law is a fair model of the ball's elastic behavior. For one datum, a force of 24 kN exerted by each jaw of the vise results in a 0.4 mm reduction in the ball's diameter. The diameter returns to its original value when the force is removed. Modeling the ball as a spring, find its spring constant.
F = kx
not sure about other equations
a.
At first I tried to use impulse but failed..
I = F Δt, then I can't continue..
b.
F = kx
24 x 103 = k * 0.4 x 10-3
k = 6 x 107 N / m
Do I get it right for part (b)?
Thanks
