Banking curve problem (find maximum speed)
A car traveling around a circular curve with a radius of 42 meters can achieve a maximum speed determined by the frictional force, which is 20% of the car's weight. The relevant equation for maximum speed is v = √(rg), where g is the acceleration due to gravity. Calculating this gives a maximum speed of approximately 20.29 m/s. The discussion also touches on the relationship between centripetal force and friction, noting that static friction plays a crucial role in maintaining the car's motion around the curve. Understanding the dynamics of friction and centripetal force is essential for solving such physics problems effectively.
5ymmetrica1
A car travels around a circular curve on a flat, horizontal road at a radius of 42meters.
the maximum frictional force between the tyres and the road is equal to 20% of the weight of the car
calculate the maximum speed at which the car can travel around the curve at a constant radius of 42 meters
I think I am supposed to use v = √rg
But I don't have a set of answers for these problems so I am not sure as this doesn't include the part of the question, the maximum frictional force between the tyres and the road is equal to 20% of the weight of the car
v = √42*9.8
∴ v = 20.29 m/s
v = √42*9.8
∴ v = 20.29 m/s
The centripetal force is mv^2/R but what force is in play to produce that force ? It's not mg since that's the weight of the entire vehicle. What's the static friction force?
I haven't studied any formula for static friction at this time in my physics course so I'm not quite sure what you mean sorry.
I know Fw = Fg (and Fv is equal but opposite in direction)
and that when split into vector components Fh = Fc
so is the frictional force Ff = FN (Normal force)?
You don't need the actual formula of friction since you know Fμ=0.2*G
If yo have a weight W sitting on the table and the coefficient of static friction is μ, how much horizontal force can you apply before it starts to slip?
