Baseball and medicine ball thrown with different KE/P/V
The discussion revolves around the physics of catching a baseball versus a medicine ball, specifically focusing on the effects of mass and speed on momentum and kinetic energy. The choices presented for throwing the medicine ball include maintaining the same speed, momentum, or kinetic energy as the baseball. It is concluded that throwing the medicine ball at the same speed as the baseball is the most challenging option due to its significantly greater kinetic energy and momentum. To determine the relative difficulty of catching the medicine ball with the same momentum versus the same kinetic energy, participants suggest using numerical examples to calculate the required velocities. Ultimately, understanding the relationships between mass, speed, momentum, and kinetic energy is crucial for evaluating the ease of catching the different balls.
bdh2991
Your physical education teacher throws a baseball to you at
a certain speed and you catch it. The teacher is next going to throw you a
medicine ball whose mass is ten times the mass of the baseball. You are given
the following choices: You can have the medicine ball thrown with (a) the
same speed as the baseball, (b) the same momentum, or (c) the same kinetic
energy. Rank these choices from easiest to hardest to catch.
p = mv
KE = 1/2 m v^2
i originally thought it would be a, c, b, but i know that's wrong now and i don't know how i can derive the right answers mathematically with variables
Think about that answer. If you catch something 10 times heavier going at the same speed, it's kinetic energy and its momentum are both going to be multiplied by 10. So given that you have a choice between the same momentum, the same kinetic energy, or 10 times as much momentum and kinetic energy, I'd say the choice "a" is by far the worst option.
In order to keep the same momentum and kinetic energy for the heavier ball, it's speed would have to be reduced, so b and c would make much more sense.
ok i understand how a is the worst but how would you be able to tell out of b and c is easier/harder?
I recommend plugging in some numbers to both formulas, say... .5 kg for the baseball and 5 kg for the medicine ball. Then make up a velocity for the baseball to be going. Solve for momentum and kinetic energy. Once you get momentum in kgm/s and kinetic energy in joules, then plug those in for the medicine ball with 10 times as much mass, and solve for the velocity the medicine ball would have to be going for the momentum/KE to be the same.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
