Finding the Capacity of a Jug Using Basic Algebra
In summary, the problem involves a man with a ten gallon keg of wine and a jug. After removing a jug full of wine and filling the keg with water, and repeating the process once more, the keg contains equal quantities of water and wine. The capacity of the jug can be found by setting up a quadratic equation and solving for the appropriate root, which in this case is approximately 2.9 gallons. The key concept in solving this problem is to prioritize concentration over quantity.
hms.tech
247
A man had a ten gallon keg of wine and a jug. One day, he drew off a jug full of wine and filled up the keg with water. Later on, when the wine and the water had got thoroughly mixed, he drew off another jugful and again filled up the keg with water. The keg then contained equal quantities of water and wine. What was the capacity of the Jug ?
Algebra
Here is what I think should be the correct solution :
Let x be the capacity of the jug
10-2x = 2x
∴x= 2.5 Gallons
Am I correct ?
It's impossible to know if what you are doing makes sense (whether or not "2.5 gallons" is correct) because you have not said what you are doing. What do "10- 2x" and "2x" represent? If you intend "10- 2x" to represent the the amount of wine in the keg you are wrong because the second jug drawn off is NOT all wine.
Hmm... I hadn't thought of that.
In that case, I would amend my method to :
10 - x/2 - x = x - x/2 +x
Left side : we removed x gallons of pure wine from the keg, and then afterwards we took another jug full of WINE and WATER (mixed in equal proportions since the question explicitly states "thoroughly mixed")
Right side of the equation : we added x gallons of pure water to the keg, then were forced to remove x/2 water from the keg (unintentionally) and later added x gallons of pure water
The answer comes out to be 5 gallons .
Is it correct now ?
No, "thoroughly mixed" does NOT mean "equal proportions" unless your jug happened to be exactly 1/2 the size of the keg- since you are assuming that, it should be no surprise that you get "5 gallons", half the size of the keg! For example, if the size of the jug were 1 gallon, you would have removed one gallon of wine so that the keg has 9 gallons of wine left. Adding one gallon of water, you now have 9 gallons of wine and 1 gallon of water so that, after "thoroughly mixing" each gallon contains 9/10 gallon of wine and 1/10 gallon of water.
If the jug were really 5 gallons, after the first removal of wine and addition of water, you would have 5 gallons of wine and 5 gallons of water- "thoroughly mixing" each gallon would be half wine and half water. Removing 5 more gallons would remove 5/2= 2.5 gallons of wine leaving 2.5 gallons of wine. Replacing that with water would give 2.5 gallons of wine, 7.5 gallons of water, NOT "equal quantities".
You are told, rather, that after the second jug is removed, and replaced with water, you have "equal proportions" of wine and water.
Is it correct now ?
The keg initially contained 10 gal of wine. You remove x gallons and replace with water, you now have 10- x gallons of wine in the keg, x gallons of water. After "thoroughly mixing", each gallon in the keg contains (10- x)/10 gallons of wine, x/10 gallons of water.
The second jug, then, removes x(10- x)/10 gallons of wine, leaving (10-x)- x(10- x)/10= (100- 10x- 10x+ x^2)/10= (100- 20x+ x^2)/10 gallons of wine in the keg.
If the keg then "contains equal quantities of water and wine", that is, 5 gallons of wine and 5 gallons of water, we must have (100- 20x+ x^2)/10= 5. So 100- 20x+ x^2= 50 and then x^2- 20x= -50. Solve that equation for x.
That quadratic equation has two roots, only one of which is valid for this problem.
Got it . So the underlying concept was to prioritize "concentration" over quantity
I'm not sure I like the word "prioritize" here but, yes, you need to work with the concentration.
By the way, what answer did you get?
10-5(2)^0.5
≈2.9 gallons
1. What is the purpose of basic algebra?
Basic algebra is a branch of mathematics that focuses on manipulating symbols and solving equations to find unknown values. It is used to solve real-world problems involving quantities and relationships between them.
2. What are some common algebraic operations?
Some common algebraic operations include addition, subtraction, multiplication, division, and exponentiation. These operations are used to manipulate and simplify algebraic expressions and solve equations.
3. How do I solve an algebraic equation?
To solve an algebraic equation, you need to isolate the variable on one side of the equation by using the inverse operation of the one that is being performed on the variable. For example, if the variable is being multiplied by a number, you can divide both sides of the equation by that number to isolate the variable.
4. What are the rules for simplifying algebraic expressions?
The rules for simplifying algebraic expressions include combining like terms, using the distributive property, and following the order of operations (PEMDAS). It is also important to remember to apply the same operation to both sides of the equation when simplifying.
5. How is algebra used in the real world?
Algebra is used in many real-world situations, such as in finance, engineering, and science. It is used to solve problems involving unknown quantities, such as finding the missing side of a triangle or calculating the cost of a sales tax. It is also used to analyze and interpret data in various fields.
  • Mechanical Engineering
