Solve L=2 Atom Problem: Find Min (L_x)^2 + (L_y)^2
  • Thread starter Thread starter PsychonautQQ
    Atom
To find the minimum value of (L_x)^2 + (L_y)^2 for an electron in an l=2 state, the total angular momentum L is calculated as L = (l(l+1))^(1/2), yielding a value of 6h(bar)^2. The maximum value of (L_z)^2 is determined to be 4h(bar)^2, leading to the conclusion that (L_x)^2 + (L_y)^2 must equal 2h(bar)^2 when considering conservation of total angular momentum. The relationship between L_x and L_y states is tied to the quantum numbers associated with angular momentum. Understanding these relationships is crucial for solving the problem effectively.
PsychonautQQ
For an electron in an atom that is an l=2 state, find the smallest value of (L_x)^2+(L_y)^2.
okay so L = (l(l+2))^(1/2)
and that squared with l =2 would be 6h(bar)^2
kind of running into a wall here..
Or is it the maximum value of (L_x)^2 + (L_y)^2 occurs when (L_z)^2 is a maximum value? and L_z = m_l*h(bar).. which would have a maximum value of 4h_bar^2 so therefore L_x^2 + L_y^2 would be 2h(bar)^2?
Ps I need to learn LaTex X_x
l=2 tells you the Lz state.
How do the Lx and Ly states relate to that?
Hint: conservation of total angular momentum.
